![]() | Home > Technical > Speedo now reading double |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Is it a case that the speedo drive on a disco is different to a defender? Or is the ECU reading it differently. So can you swap ECU from disco or modify your defender one? Do you have a Nanocom?
Andy |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
I am afraid we have tried that and others. As far as I know we have tried them all including v8
Although its a td5 (v) with a td5 dash it's running a 300tdi. I am guessing this is part of the issue but can't see how. It worked befor the box change and I have been told it ran disco box prior? |
Quote
The difference between the defender and disco sender is the disco gives twice as many pulses. So on a programmable speedo either will be fine. On a standard defender td5 speedo it's set to 4100 pulses per mile. Still looking into it. |
I think you answer is in here.
http://forums.lr4x4.com/index.php?showtopic=70254#entry600667 Andy My head hurts now |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Woo Hoo, at last a Defender that does 50 MPG
![]() Steve |
For your information
"For what it's worth, the Disco transducer unit (the small black one, think it has an AMR part number) reads double the number of pulses that the Defender Td5 one (YBE100530) does. For a Defender Td5 speedo, YBE100530 is what you want. Anything else will mis-read, and a non-genuine YBE100530 will double-read. Never heard of a Britpart YBE100530 not reading double! " Andy |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
Another triumph for our favourite parts supplier! ![]() |
Genuine one on order! Should have guessed with britpart was the same price nearly as well.
Cheers Was waiting to get stopped by plod yesterday do you know what speed you were doing???? |
Just thought I would update this as fitted the genuine part today and it works.
Lovely britpart does it again I have said before I will never buy britpart again am I a sucker ![]() |
