![]() | Home > Td5 > Remapping td5. Need more air. |
pesto_trader Member Since: 26 Jun 2013 Location: Oslo Posts: 148 ![]() ![]() ![]() |
I tried remapping my Defender 90 td5 04/05 a couple of months ago. Was very happy for a while. Then remapper from Bell Auto Services made me aware of black smoke. We took off the centre part of the snorkel, but nothing changed. He checked the air flow meter, which was fine. I think he used a nanocom or something. And it says its peeking at 500. He said 600 is where you want to be. Any thoughts on this issue? Is the snorkel the problem? It was such fun driving a slightly faster and stronger Defender.
Thanks guys. Peter |
Postmanpat Member Since: 01 Aug 2012 Location: Co.Limerick Posts: 50 ![]() ![]() ![]() |
would bypass the snorkel and see , its know that with a snorkeler you off-set some of the improvements ... Postmanpat
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5982 ![]() ![]() |
Do test with the top off the air box, this will tell you if it is worth messing about with the intake system.
Andy |
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 435 ![]() ![]() ![]() |
try a induction kit like mine, it makes the biggest difference ever! i will put a picture into my profile now.[/img]
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Slightly low boost pressure can also keep the maff reading down!
Thanks guys! Hope i can fix this myself.
austinhealey55 Member Since: 09 Sep 2013 Location: Lusaka, Zambia Posts: 24 ![]() ![]() |
Does your Td5 have a catalytic converter? If so, it could be the issue of low MAF and turbo values, especially if you've done all the checks on the intake (cleaned intercooler, checked intake hoses, removed or checked EGR, new air filter, checked intake for blockages before air filter, have a known working MAF installed, etc.). Not all Td5s had cats though.
My '03 Td5 cat was totally blocked... and if the air can't get out, it can't get in either. I had low MAF values and lack of turbo pressure, and fixing this restored things to normal. You can check if yours has a cat by looking just aft of the front wheel, passenger side (on RHD). Yellow arrow points to it in the photo. Not a bad job to check/clean or replace it, can post more info about doing so if it'll help. Cat as installed: ![]() Click image to enlarge Downpipe w/ cat: ![]() Click image to enlarge |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
out of intrest did you ever sort this?
Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
