Home > Camping, Caravanning and Holidays > Carrying an oztent and a maggiolina
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
I am thinking about changing our camping arrangements and quite fancy the tents named above. I already own a howling moon tourer with stargazer annex but would like a roof tent that is quicker to put away and want the oztent to take the place of the annex. I also use a foxwing which would obviously suit the oztent well.
My query is how to carry both a maggiolina and an oztent on the roof rack of my double cab (full length Hannibal).
Has anyone done this?
Thanks in advance
Jim
Post #261769 27th Aug 2013 10:12pm
sense of adventure
United Kingdom 2010 Defender 110 Puma 2.4 USW Galway Green
Yes, but if I say how I will be accused of commercial posting.
Post #261770 27th Aug 2013 10:14pm
Jimb1978
Pm?
Post #261771 27th Aug 2013 10:15pm
sense of adventure
How do you post a phot to here using an iPad
Post #261775 27th Aug 2013 10:25pm
Jimb1978
Ok, great.
That looks like it was a good trip!
Is the tent just lashed to the roof rack or did you make brackets?
Post #261779 27th Aug 2013 10:30pm
Jimb1978
I use photobucket but that link worked just fine
Post #261780 27th Aug 2013 10:31pm
sense of adventure
No lashing stuff on here, built properly is the only way
Post #261783 27th Aug 2013 10:33pm
a13x
I have seen an oztent attached to the side of a rack before but couldn't say how.
Does it have to be an oztent? We have both oztent and a tentipi with stove and find the tipi a preferred option, only takes a few mins to pitch, Infact is quicker than the oztent as still have to fit sides and guy out etc. Also have a foxwing but is still in the garage awaiting arrival of the hannibal rack.
Once finally here and installed we will be trialling the awning and sides together with tipi to see how things go.
Post #261792 27th Aug 2013 10:59pm
leeds
Why not use a Maggiolina side awning M11/A?
OK not the same amount of privacy as the Maggiolina changing room. Dependent on height of your vehicle you would need either the M13A-2 or more likely the taller M13a-3 as the changing room.
Your Hannibal rack is 1.41 m wide, 2.75m long whereas the small Maggiolina are 1.3 m wide and the medium are 1.45 m wide and 2.1 m long
Some of the Maggiolina range can have loads on top, dependent on roof tent that is about 15-20 kg which would limit it to the smaller Oztents.
Brendan
Post #261798 27th Aug 2013 11:40pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Fyi, i have a medium maggiolina fitted with foxwing. Concerning the width they are a bit wider then the roofrack but not on the bottom. See my avatar or galery if you want pictures.
Post #261811 28th Aug 2013 7:43am
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Brendan
Hi Brendan,
sorry to go O/T but what are the M13a-3 changing rooms like? not much info on the internet or actual pictures of in use. Such as ease of putting up, room inside, quality of material?
Back on topic, I had a Maggiolina and an Oztent. Never really got on with the Oztent which was a small one, I carried it inside a 90 which didnt really work so sold it and bought a 2.4m Hannibal awning and sides. This works very well but only has 3 sides which I dont like. Seriously thinking about the M13a-3
Steve
Post #261814 28th Aug 2013 8:08am
Jimb1978
I really need a setup that is quick and easy both to pitch and to put away. I guess most combinations are possible with a little thought and homemade bracketry!
I have seen images of the maggiolina annexes but they look a little small. The family has grown by 2 since we bought the howling moon back when we first got married, so need to sleep 4 in comfort.
Brendan, I only live in huddersfield so could view stock if that is possible? I hope I don't offend by saying that back when we bought the howling moon we did come to your house to look at maggiolina stuff. Sorry. I kind of wish I had listened to you because it wouldn't have meant a potential second purchase.
Post #261816 28th Aug 2013 8:15am
leeds
Just a couple of ideas.
Maggilina linked to an Oztent
Now is this a new quick erect rooftent?
Am a bit dubious amount the standard peak side panels fitting correctly Razz
Shows how versatile this tent is
Brendan
Post #262313 29th Aug 2013 11:21pm
Shep
2010 Defender 110 Puma 2.4 USW Orkney Grey
Thats interesting I too have a tentipi with a wood burner, but was thinking about getting a OZ Tent for one night stopovers etc i assumed it would be much quicker to erect and take down than the tipi?
I love the tipi but for one night stopovers the tent & the floor takes time to put up and longer to pack away neat.
Love to hear what take the time with the OZ?
[/img] A man with no boat is a prisoner
Post #264001 5th Sep 2013 5:49pm
Putting up the basic OZ tent takes minutes. It stands up on it's own and then only needs six pegs to hold the shape. Packing away is equally straightforward.
I've used an OZ in its' basic form on a move every day trip and it was very easy to live with.
Adding the panels to make the front porch into a room takes longer as there's more pegging and guy ropes involved. Darren
Post #264009 5th Sep 2013 6:33pm
