|  | Home > Puma (Tdci) > Many Thanks Chris@CSK |
| superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314      | OK, New pump picked up from local dealer:-
   Click image to enlarge Old pump:-   Click image to enlarge and half hour later fitted:-   Click image to enlarge Only obvious difference to me is that the one I took off is made in England the new one is made in France. Lets hope that cures it... Cheers, Superspoons | ||
|  22nd Aug 2013 3:23pm |
| superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314      | Just a quick update to say that after a 250miles tri, no further oil leaks under the bonnet - Looks like the brake servo unit was the issue    Cheers, Superspoons | ||
|  27th Aug 2013 4:59pm |
| Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015      |  Good to hear   Glyn    | ||
|  27th Aug 2013 6:14pm |
| miket Member Since: 05 Oct 2012 Location: Peak District Posts: 143  |  .  I was wondering where that light spray of oil on the bonnet was coming from and now I know... Is it difficult to replace the pump yourself if you're not a qualified mechanic? Looks like I'll have a whole new Defender at this rate, part by part. | ||
|  27th Aug 2013 8:51pm |
 Dead easy. Have a read here http://www.defender2.net/forum/topic16139.html and there's a link to a LR document on how to do it. Took me an hour all in to do it. Cheers, Superspoons | ||
|  27th Aug 2013 9:07pm |
| miket Member Since: 05 Oct 2012 Location: Peak District Posts: 143  | Thanks, sounds hopeful, do you have the link to the LR how to do it?
 Cheers Mike | ||
|  27th Aug 2013 9:11pm |
| Posting Rules
   I see the problem...... your bonnet is FAR too clean, are you related to Zagato? lol. TBH, if that is all there is there isn't much need for concern- just keep an eye on it every now and then and wait to see if it gets worse
 I see the problem...... your bonnet is FAR too clean, are you related to Zagato? lol. TBH, if that is all there is there isn't much need for concern- just keep an eye on it every now and then and wait to see if it gets worse  . Or were these pictures after a clean?
