Home > Maintenance & Modifications > Washers on wipers - storm wipers
Cheshire110
Link to ebay product here - http://www.ebay.co.uk/itm/390650027185?redirect=mobile
Anyone had any experience? I've bought them because they're only Ł20 and I need new wipers anyway so not got a lot to lose.
Not sure about in cold weather, will they freeze up more?
No mention of fitting either...
Any advice appreciated, and I'll let you know what I think when I get mine. Cheers, David
Post #261528 26th Aug 2013 10:44pm
Sockpuppet
Most of the lorries I drive have wipers like this and they're a lot better than the standard jets.
Post #261529 26th Aug 2013 10:47pm
Cheshire110
Interesting, if trucks use something it's usually good for the job.
Disappointed at the lack of info on the page, no fitting / actual picture / description of actual product / number of nozzles per blade etc.. But will wait and see! Cheers, David
Post #261530 26th Aug 2013 10:51pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
I reckon thy,re worth a go for Ł20, I see what you,re thinking about with regard to freezing but a good quality screenwash at the right strength for the conditions would probably see to that.
Will be interested to see what you think when you have them fitted. 2005 Td5 90 XS
Steve
Post #261531 26th Aug 2013 10:55pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
I have a version I made up on my Defender. Much better than standard
Post #261532 26th Aug 2013 10:57pm
Cheshire110
*IF I get them fitted haha!
Hopefully some instructions will come with Cheers, David
Post #261533 26th Aug 2013 10:57pm
Cheshire110
Do you have 2 nozzles or one per blade? Is there a thread somewhere or some pics? I'd be interested to see your setup. Cheers, David
Post #261534 26th Aug 2013 10:58pm
GUM97
As Sockpuppet said, a lot of trucks have them fitted. Pretty good to be honest. However, Ł20 is overpriced (even though it sounds cheap!). It's about Ł6 trade Laughing An engine to TDi for!
Post #261547 27th Aug 2013 6:02am
Cheshire110
Yeah, but if they're good it'll be worth it. A newest of wipers would be 6-10 anyway so I don't really mind the bit extra if they're good. Cheers, David
Post #261554 27th Aug 2013 6:54am
I guess the tricky bit would be to make the water pipes from the centre look ok as they are run along the front of the bulkhead
Peugeot do the same, might be an option... Either a scrapyard or dealer ?
Post #261558 27th Aug 2013 6:59am
Cheshire110
Yeah, not sure how it will look but will do my best to make it work. Cheers, David
Post #261564 27th Aug 2013 7:41am
Possibly use the other wiper grommets and poke the water pipes up thru there
If you use the correct fluid, it won't freeze up in the pipes
Post #261569 27th Aug 2013 7:57am
WarPig
I've fitted Peugeot spray arms to my wipers. Took a T junction off the original pipe and thread the pipes through the bulkhead.
Post #261579 27th Aug 2013 8:45am
borderterrier
Here's mine
Post #261590 27th Aug 2013 10:06am
Cheshire110
Here's mine
Looking good! Cheers, David
Post #261610 27th Aug 2013 12:11pm
