Home > Technical > Heated Breather Modification LTB00196 for arctic regions
Page 4 of 7 <1234567>
Kris
you have an email
Steve
Post #187816 24th Nov 2012 12:24pm
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Thanks Steve Thumbs Up
As a note for anyone in the future: The kit I bought came with a harness for a LHD car. I spent ages looking on the drivers side for the plug it went into and then realised it would be the fan on the opposite side so cut the loom up and extended.
Checked it once it was in and with the fans on setting 4 it warmed up to touch within about 30 seconds.
Post #187880 24th Nov 2012 4:54pm
Kris
that's because your steering wheel is on the wrong side Thumbs Up
nice little kit and you can take the fuse out for the summer ... I must remember to put it back in before you know what !
btw - does it make a difference on the fan setting ? I thought it just used the fan +ve feed - but happy to be corrected
Post #187888 24th Nov 2012 5:14pm
Phoenix90
Yes, would be very upsetting to suffer failure for forgetting a fuse!!
I assumed the fan speed was controlled by varying the voltage to it at the plug where the heater joins in. Just an assumption though. I'll put a meter on it tomorrow when i'm back out there.
Post #187918 24th Nov 2012 6:09pm
I've put the fuse back in just to be safe ..
Post #187939 24th Nov 2012 6:48pm
Phoenix90
Laughing Thumbs Up
Post #187957 24th Nov 2012 7:04pm
D'MARIQUE
Russia
Has anyone tried the heater kit for the Ford Transit?
They had the same problem & the dealer's fixing the bug till today for free, because of "safety measures" Thumbs Up
Transit kit should cost less than LR, I suppose...))) Anyone tried?
Post #261398 26th Aug 2013 3:54pm
It's probably the same heater
Another alternative would be to fit an oil catch tank and block off the air box hole
Post #261402 26th Aug 2013 4:12pm
ericvv
Добрый вечер D'Marique,
Welcome to the forum as I see this is one of your first posts. Where abouts in Russia are you, and which Defender are you driving there? I know your country pretty well, anywhere from Moscow down to Volgograd, Voronezh, Belgorod, Rostov, Stavropol and Krasnodar oblasts. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #261415 26th Aug 2013 5:04pm
D'MARIQUE
Russia
Eric
Привет, Ericvv!
Yes, right, I'm newbie here))) Bought my Def couple months ago: it is 110 '08. Awesome wagon with it's own character & soul))) Thumbs Up
In Russia I live in Ekaterinburg, Ural & travel around the region mostly))) Now, with my Def I will widen my traveling area in the country for sure Very Happy
Post #261552 27th Aug 2013 6:44am
dgardel
Italy
Welcome on board D'MARIQUE! Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #261571 27th Aug 2013 8:05am
dgardel
Italy
Taken from a Rented Peugeot (came from 65CV Diesel 2013 208) Evil or Very Mad
Need time to install
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #262934 1st Sep 2013 5:25pm
D'MARIQUE
Russia
Wow! ts nice! Whistle
Looks like it will fit perfectly Wink
P.S. I thought it couldn't be that cold in Venice Smile
Post #263028 2nd Sep 2013 3:10am
dgardel
Italy
Rolling with laughter Yes in Venice area the winter it is not so hard.....
but in Alleghe, in the Alps, where my father in love live, normally arrives at -22.
IID Pro MV License
Post #263030 2nd Sep 2013 5:33am
D'MARIQUE
Russia
-22 - it's a nice warm winter, i should say))) Rolling with laughter
I'm also thinking of another heating option - FLEXIBLE TAPE HEATER
Seems easy to install & to use. Costs about $30 for 1 meter, 12V.
http://www.homakoh.ru/production/auto-en/engl/
Post #263032 2nd Sep 2013 5:41am
