![]() | Home > Td5 > Resistance is futile - well some odd earth results I think.. |
This thread but for a Puma page 3.......I slammed on the brakes and the same symptoms ensued.....
http://www.defender2.net/forum/topic2394.html?highlight=chaffed Not wishing to teach 'egg sucking' but presumably to prevent parallel earths the ABS ECU, ABS Pump Relay and the connector should be electrically disconnected when carrying out the resistance checks? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Landyphil Member Since: 23 Jul 2012 Location: Lake District Posts: 87 ![]() ![]() ![]() |
Yep they should be disconnected depending on what you're testing.
I should maybe add I design/repair/ generally mess about with electrical systems on large industrial plants.... I'd seen that thread although I admit I've never had just ABS/TC lights on ever. Only all 3. Belled out all ABS sensor wires on both vehicles. There's within a gnats fart of each other. Some of the folk discussing that earth connector (K108) behind the coolant header tank is definately the next port of call. It's just a sod to get to! 90XS Tdci John Eales 110 CSW G4 Edition 88" Series 3 Racer |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
When I had the three amigos it was a bad connection on one of the terminals on the bottom of the relay under the drivers chair. I can't remember which one but it was obvious when I finally spotted it. It was caked in the green coloured corrosion and when I pulled the wire it came straight off the connector. Crimped and resoldered a new terminal on and job's a good un.
Hope you find the problem soon Jim |
Cheers Jim,
I'd seen your thread and have been through all the connections under the seat relating to the ABS system. Depressingly immaculate in these circumstances! ![]() Next test will be to run a test wire from the battery earth to K108 and see if it works. For the minute though it can sit there! 90XS Tdci John Eales 110 CSW G4 Edition 88" Series 3 Racer |
Well at lunch today I ran a strap wire direct from the battery negative to K108 earth stud. Result was less than 0.1Ohm earth at the ABS connector (It even improved the ABS connector to earth stud results)
Despite a couple of restarts it still has the lights on the second you start up. So next plan is to get a data sheet for the ECU. As I said above it appears that the ECU injects a voltage and looks for a resistance within the motor. Obviously infinate and 0 are definate motor failure figures (or wiring issues) but what tolerance does it have on the Ohmic figure? Because whatever that figure is the working on is within it and the faulty one isn't. Either way putting a few volts across a motor and measuring it's resistance is a very unreliable way of testing an electric motor unless you're looking for 0 or infinity. So lets see who knows what that ABS ECU has in it's dataset....I have a sneaking suspicion Land Rover might not be so forthcoming. (If they know that is) 90XS Tdci John Eales 110 CSW G4 Edition 88" Series 3 Racer |
With Hummers using the same modulator block there may be some values in the public domain on the other side of the Atlantic.
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 675 ![]() ![]() |
Have you checked the sensor on the wheel that hit the pothole to check its still mounted ok, connector etc.
Personally I'd start here. Cheers Steve |
I checked all the sensors they're perfect. And a sensor would bring up ABS/TC I believe not WARNING/ABS/TC
Far side of the pond has proved fruitful. Got an installation manual from WABCO website and although it doesn't have Ohm values for what is acceptable/unacceptable. But what I did do was manually fire the pump relay. Pump worked a treat and low and behold the lights went off! Still got 8 ohms between Pump positive and earth but now that's acceptable to the ECU!?! I've made some enquiries regarding that figure.... 90XS Tdci John Eales 110 CSW G4 Edition 88" Series 3 Racer |
Well Land Rover themselves claim not to know!!!!
ECU testing reckon it's a goner so a quick question: Other than the re arrangement of the output ports whats the difference between the discovery unit and the Defender ABS modulator unit? 90XS Tdci John Eales 110 CSW G4 Edition 88" Series 3 Racer |
Well I still don't believe the ABS pump has gone.
Lot of measuring of details between working and faulty LR shows that the ABS ECU is seeing a resistance a 5.6Ohms on the good one and 6.7Ohms on the faulty one. And......persuade a spare ECU just plugged in on the faulty landy that all is well and head off and to an emergency stop on gravel (handy living offroad) and the ABS works..... for a while then the ECU says its curtains. So not a penny will be spent on new pump until SOMEONE tells me what the criteria the ABS ECU uses to determine pump failure. Bit worrying that my local dealer can't find out. ![]() 110 CSW G4 Edition 88" Series 3 Racer |
Sympathies fella,I get the impression it's a black art fault finding these things,I'm gonna try sacrificing a goat if mine comes on again. Good luck with it.
Going back to basics, you can proove that the mechanical side of the system works(well the hydraulics do what they are supposed to do) the only moving parts, bit of guessing, within the modulator block will be the shuttle valves and these are controlled by the two solonoids which are themselves controlled by the ABS magic box which interprets the signal inputs. IIRC your 110 is slightly newer than mine(2002) but with mine I have the "shuttle valve failure 255 times" which on a Discovery is sorted by by-passing the pcb in the modulator and joining to the loom before the multi-plug to the modulator and continuing to earth. The Defender looks the same allbeit a different colour code on the loom.
I took the solonoid plate off mine and soldered new wires as described on a previous post above but the fault has returned but, when I opened the solonoid pack there was a lot of crud in the casing plus the insulation on the wiring was pretty dodgy ![]() Click image to enlarge I will, when I get the chance, open it all up again and see if I can replace the wires right back to the solonoids themselves as the wires themselves looked like they had started to break down with corrosion. A complete overhaul of the earthing points will be done as well. Personally I can't see that much else can be wrong, but that's my view from one that prefers a bigger hammer to a soldering iron! |
It's coming up with pump failure code rather than SLS but not having an internal wiring diagram of the module I'm still
![]() Give me a diagram and I'll have a go at any electrickery. ![]() 110 CSW G4 Edition 88" Series 3 Racer |
I know where you're coming from with the watering the breeze when it comes to seeing where the electrickery goes inside the boxes
