Home > Maintenance & Modifications > Will foxwing awning fit on a 110 Front Runner roof rack?
Odin
Scotland 2012 Defender 110 Puma 2.2 USW Santorini Black
Will the standard fit work or will I need special brackets? Anyone done this?
Post #261414 26th Aug 2013 6:02pm
a13x
I've not done it yet but I can't see why not. That being said I have the foxwing and a set of brackets purchased through Brendan but can be seen on the Boab website. Believe they were £50.
These are specifically for the foxwing to mount to a rack like the frontrunner and is what I will use when the hannibal rack finally arrives.
Post #261424 26th Aug 2013 6:48pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Yup
Post #261425 26th Aug 2013 6:54pm
leeds
The standard brackets supplied with the Foxwing is designed to fit on the Rhino Rack roof bars.
You might be able to adapt them to fit the Front Runner roof rack. However depending on your height, your vehicle set up you might struggle to put the Foxwing away due to height above the ground.
We do have the Tracklander fitting kit in stock although they are not on our website at the moment.
Any questions ask away.
Brendan
Post #261429 26th Aug 2013 7:09pm
Odin
Thanks Brendan. So with the brackets I can fit the foxwing awning to the front runner rack. How much for the brackets?
Post #261474 26th Aug 2013 9:16pm
leeds
Brackets are £50.
If you pm me your delivery post code will work out best delivery option and cost.
Brendan
Post #261481 26th Aug 2013 9:31pm
Odin
Thanks Brendan for your time today - great advice as ever. Will be in touch to place order once I've the cash.
Post #261668 27th Aug 2013 6:37pm
