![]() | Home > Puma (Tdci) > A faint whistle - engine speed related |
| pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489
Sounds like a leaking turbo gasket to me.
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
If it were gasket related would it not make noise all of the time?
Would there not be a drop in power from such a leak. Rossy said "which mostly occurs when you take your foot off the pedal to slow down. " When you take your foot off the pedal your revs drop so the vehicle is quieter. Maybe it is standard turbo whistle not normally audible owing to road noise from the wide tyres and the engine noise. Would James French not have noticed anything untowards turbo gasket wise when they test drove it? I only hear the turbo when I ease off the power and things quieten down. A leak would imply a pressure drop which would effect power. If you don't notice any difference when overtaking I'd say all is O.K. If there was a leak in the gasket would you not be able to detect this at the gasket? 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
| keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2279
Cracked inlet manifold ?
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21033
My goodness all you lot are trying to put the fear of god into him think with what "could" be wrong.
Mine does the same in the same way also, it's the turbo spooling down if you ask me when the revs drop off the engine noise is reduced and the turbo is more audible for this reason. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297
I hope you're right custom90steve ! Sounds like the right answer to me |
Ears recently syringed? 1982 88" 2.25 diesel
If you feather the throttle in a gear for example 4th is a good one you will notice it on flat ground. Just a faint tap and then off and that'll likely be when you notice. I always find it's when the revs drop and when not under load. So always flat ground or slightly heading downhill. ____\We|Will|Win/___
A leaking gasket is hardly scary!
It cost around £15 with new nuts and about an hour of my time to fix. |
| All times are GMT |
