![]() | Home > Puma (Tdci) > Odd incident after disconnecting/connecting battery |
| Rakthi Member Since: 30 Nov 2012 Location: Where the cats are Posts: 200
Hi guys, had to take the battery out so I could clean up/neutralise some spilled acid (breathing tube battery had dislodged) and water that had gotten in during some wading.
After putting everything back and reconnecting it, started the truck but the battery light stayed on and the water gauge went to the top. The UltraGauge didn't boot either. ... switched everything off and tried again a couple of times. No joy. Waited a minute or two, tried again and everything back to normal!?!? Did a search on the site and only this 2-year-old post from "doublea" showed up
http://www.defender2.net/forum/post79919.html#79919 No chafing wiring loom here, no blown fuses and no cutting out engine, the UltraGauge doesn't show any codes either ... Just curious if anybody had this happen or has a clue what this could have been? |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
lost synchronization between ECU and instrument cluster (by CAN network) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
Thanks guys!
Guess either could be the culprit. Next time will unplug the UltraGauge before disconnecting battery ... Just glad "it" sorted itself. |
| All times are GMT |
