![]() | Home > For Sale & Wanted > WTD - Tdci 110 diff guards |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2789 ![]() ![]() |
Nope, no bolt holes! Strange eh? Front diff guard sounds good! Will it fit mine? How much do you want for it? I could probably cope without rear diff guard tbh! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Rakthi Member Since: 30 Nov 2012 Location: Where the cats are Posts: 200 ![]() ![]() |
Hi David, not so strange ... my 2011 doesn't have the bolt holes either. And some other people on here have reported same.
I have a QT rear diff guard sitting around here ... might install it anyway, should be reasonably secure even without the bolt holes. (well at least it won't fall off). Might not give the full protection it would give with it bolted up the way it is intended to be, but still better than the thin plate on there now. |
Without any fixing on the nose of the diff, isn't there a real danger of the front catching and creating a bending moment around the upper fixing. May end up acting as a plough? |
How much do you want for the front one Glyn? Assume it doesn't need any bolt holes? Cheers, David
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Hi David,
I will dig it out and double check it fits Rover front axle. It bolts to the top 2 diff studs and then to 2 holes in the bottom of the diff housing. How does £30+postage sound? (Prob about £5) Glyn ![]() ![]() |
Sounds perfect! If you could get back to me with fitting info or a pic or whatever, I'll get under the car and double check. Cheers, David Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Any luck? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Still looking for a QT front diff guard then if anyone has one? Cheers, David
