![]() | Home > Maintenance & Modifications > puma clutch fluid reservoir |
| skyeplumb Member Since: 22 Apr 2013 Location: Isle of Skye Posts: 134
high up on the bulkhead on the drivers side (assuming RHD) in the engine bay - quite fddly to get the top off if it's tight (use water pimp pliers carefully) and tricky to get fluid in - i used a 200ml test tube type bottle and it only just made it.
edit - a syringe would probably be better Series IIa Lightweight - Long Gone Discovery 1 300Tdi - Sold Defender 110 XS 07MY Utility |
| 935tbone Member Since: 09 Mar 2013 Location: Northampton Posts: 7
cheers i thought it was that awkward looking one !!
| All times are GMT |
