Home > Technical > TD5 centre console wires & plugs (1999)
excossack
While putting the dash back together I found the original loom wires for the stereo which are unused as someone has wired in and additional ISO connector for the stereo.
I tried the plugs and the radio powered up but no speakers.
Where do the speaker wires run to ?
Currently I have two speakers, one either side in the headlining just above the B post.
While in there, there was another plug with about 4/5 wires into it.. Any ideas?
I will take a pic when I next remove the radio to fix non working speakers. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #260689 22nd Aug 2013 9:49pm
Retroanaconda
Speaker wires run to each end of the lower dash, where the speakers would be.
Post #260697 22nd Aug 2013 10:01pm
excossack
Ahh right, so passenger side under the wiper motor and I guess opposite side for the driver.? There are non at the mo. 1999 Defender TD5 110
Regards
John M0VAZ
Post #260701 22nd Aug 2013 10:05pm
Retroanaconda
Yep, that's it.
Passenger side the removable wiper motor cover section of the dash can be easily replaced by a version with a hole in. Given the ball-ache of removing the other dash lower section it might be easier to cut that one in situ, just watch the wiring behind.
Post #260878 23rd Aug 2013 7:08pm
excossack
I think in this instance, I will leave the dash well alone and wire the OEM plugs/cables to the headling speakers. 1999 Defender TD5 110
Regards
John M0VAZ
Post #260884 23rd Aug 2013 7:50pm
