![]() | Home > Technical > Indicator flashes fast? |
| sc70 Member Since: 29 Jun 2010 Location: Tregaron Posts: 261
drivers side indicator is flashing very fast, all bulbs working and its fine on hazards? oh its a td5 110
any ideas please! www.Equi-Trek-Tregaron.co.uk Main Dealers for Equi-Trek and Brian James Trailers |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6053
Wing repeater ok?
Do you have towing electrics? Andy |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
LEDs fitted??
Brendan |
no led indicators and all indicators working (front rear wing), it dose have a trailer plug but it in tucked up in the chassis and not used
if I put the hazards on they all flash at the correct speed www.Equi-Trek-Tregaron.co.uk
| Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015
The system is messed up- If you remove a bulb (or 2) the hazards will still work at the right speed.
On the old switch (when it was by your knee) 50% of the indicator faults was the switch, and nothing to do with the indicator stalk or bulbs. Glyn |
