![]() | Home > Technical > Suspension Advice Re: Articulation |
| Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015
Dampers, trailing arms (yes they are cranked but RJ would be even better), anti-roll-bar if you hve one and brake lines.
Gwyn Lewis is a good start- normal kits have a 5" extension over standard from what I recall. Having a 2" lift and 2" extended shocks doesn't really give you much more articulation. Other option which I have been hearing good things about is RAC parts's twister kit. Please remember to get extended brake lines- My Gwyn Lewis ones came through the post yesterday, beautifully crafted pieces of kit *Edit* Forgot to say..... Lovely looking truck you have there Glyn |
| EddieB Member Since: 08 Apr 2013 Location: Durham Posts: 57
Thanks a lot for the advice Glyn, I seaeched RAC parts on Facebook and they make a few tasty bits! What do you mean by
'RJ' when referring to trailing arms? Not sure if what I have would allow such articulation as permitted by the rac twister kit or whether I would need wide angle uj's etc. I take on board what you say about brake lines though. Ive heard many good things about Gwyn Lewis, and having spoken to him on the phone when ordering my relocation cones, he was very helpful. After a bit of research I've also come across the d44 kit with king dampers, what a piece of kit! |
| Landy-Novice Member Since: 23 Jun 2013 Location: wiltshire Posts: 118
rose jointed trailing arms. allows more flex without giving the bushes a hard time. |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6053
As above. Gwyn Lewis kit is good and tested, even improved my road handling.
Click image to enlarge Andy Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
Great pic! I see you have the damper relocation brackets and relocation cones, what dampers are you using? Are you running standard props etc? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
I am using Old Man Emu dampers, and standard front prop, but a Bailey Morris rear prop, although this was fitted before this kit, not because of it.
The clever bit of this kit is that even though the dampers are 11" longer than standard, compression of the opposing wheel is still greater than standard, or most other kits. Click image to enlarge Andy Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
I am also running the heaviest springs that are sold with the kit as a I can carry very heavy kit, with softer springs and a different mount hole used for the dampers, the kit articulates even more.
Andy |
| johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459
Very tasty andy
it looks like you have changed the trailing arms too? 2004 TD5 Defender 90 xs station wagon |
I have been asked the spec of my suspension via pm, but thought I might as well put here as others may be interested.
Mine is Gwyn Lewis full challenge kit. Apart from I did not fit his bailey Morris props as front prop on a Td5 is very good with massive uj's, and the rear one I had already changed. Brake pipes I had also changed before. I went for OME dampers, and springs, and they are great. The hole kit was simple to fit, came with clear instructions, and all the required nuts and bolts. Mine is a 1" lift, with great articulation, but mate of mine is running the same kit with 3" lift and softer springs and his articulates much more than mine. But is less stable on the road. I sometimes wish the rear was softer, but this is due to carrying less, on the road it's great and off road it's superb. It allows you to takle obstacles with care as you need less momentum, and is much more stable when dropping in to something, or crossing an axle twister, as there is less time the wheels are unsupported. http://www.gwynlewis4x4.co.uk/page56a.html I have had one bracket break, but Gwyn bent over backward to sort, at his own cost. The only thing I would do different is fit it sooner, and never fit terrafirma suspension. Andy |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
How does a lift kit and Puma come off with it's mechanics? I heard (possibly mis-informed) that anything more than a 2" lift is not a good idea at all on a Puma due to the gearbox or transfer box or some reason along those lines. (possible something that's adjusted out of position into one it shouldn't be in) Is this true? ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
Interesting question Steve, when I had 2" lowered springs on my ice edition I was getting a vibration at 100kmh up to about 110kmh, put std springs back on and all ok, could be the same for lifting |
I know that Gwyn advises that the Tdci's are not lifted or lowered more than 1" due to causing vibration.
Andy |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Did you have the wheel alignment done after you changed the suspension? Most people don't but with any change of suspension you should get a full 4 wheel alignment (although not not all camber/castor etc is adjustable) because any slight change can make a big difference in tracking, camber and castor. |
I only changed the rear springs to enable me into the underground car park, so no changes to the front set up. But to answer your question, no I did not have tracking or anything else changed,when the std springs reinstalled, all ok again. |
