Home > Puma (Tdci) > How to remove the rear sliding screens
landybehr
Hi,
I have desperately searched for but not found any description of how the later style sliding windows can be removed.
Instead Iīve only read that the complete window assy is glued in which wouldnīt help in taking it apart.
Who knows how the sliding screens are removed ?
I want to have some tinting film applied to the glass and the guy who is about to do that prefers to have the screens on the bench for a better result.
Post #260367 21st Aug 2013 5:37pm
jont
2006 Defender 90 Td5 XS CSW Santorini Black
When I looked into it for our '06 90 I was informed that I had the new-type 'glued' sort of sliding frame that can't be taken out without destroying the glass/frame ...
Had I bought a '05 or '55 it would have had the 'bolted in frame which can be unbolted and the glass remove easily for film/tinting ...
So guess depends on teh age and whether you are lucky or unlucky in what they had on the shelf at Lode Lane on that day Confused
Jon
Post #260370 21st Aug 2013 5:53pm
bob neville
Up to around 2005 ? the rear side windows were riveted in and relatively easy to remove. Later rear side windows are, as stated above, bonded in.
I am sure somebody will be along to tell you how to remove the bonded version soon - probably involves a sharp implement Shocked
2013 Defender 90 CSW - sold
Post #260377 21st Aug 2013 6:16pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
Bob
...........or heat gun... I think they are in 2 parts aswell.. Putting Dreams on Drives at JLR Solihull..
Post #260381 21st Aug 2013 6:20pm
Glynparry25
Bob:
With one of these babies you can remove the whole window assy and glass intact......... you will however need to buy some new side pannels Whistle Whistle
Glyn Dog Sheep
Post #260382 21st Aug 2013 6:21pm
bob neville
That will certainly do the job Glyn Laughing
Just found this
For bonded type:
Use your stylus knife to cut the bonding between the frame and vehicle
side panel. Eventually your frame will be loose and will come away from
the vehicle body
If in the process,the surfaces are dented or damaged, flatten them out as
best you can.
Clean the surfaces surrounding the aperture to remove any dirt or grease.
Post #260384 21st Aug 2013 6:23pm
landybehr
@Glyn:
Well, so neednīt I remove the panels inside ? Just start cutting from outside? It looks like there is a 1-2mm thick rubber gasket between the frame and the side panel.
The Window assy itself looks like it will split. Somehow "they" will have had to assemble it.
What I not quite like is that service to the seals etc. looks like being a nuisance now. (though I think there is a way of replacing the gutter seals with the screens in situ).
Post #260403 21st Aug 2013 7:21pm
