![]() | Home > Maintenance & Modifications > How many Dinitrol cans? |
| Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479
Is there a great difference between the 1litre cans and the aerosols. I'm weighing up if I can justify a compressor for the garage if there is little difference I wouldn't bother.
| Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725
Is dinitrol better than waxoyl? And if so what type is best as there appears to be many different types?
Basically.....
Dinitrol ML is a cavity wax. Inside the chassis, doors, bulkhead etc. then the underbody sealer. These are the same just one is black. One is brown. DINITROL 4941 - black, tough, elastic and waxy film DINITROL 4942 - brown, tough, elastic and waxy film |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21042
There is also brown internal wax or clear too. I've gone for brown on that so you can tell it's done plus it won't be seen anyway. The underseal will be black though. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Well I've just bought all what I need. As I'm doing stone chip too I think it's cost around the £140 region.
I've now got as of today all of this:
Click image to enlarge 8x Stone chip, 8x under body wax and 6x internal wax. Maybe a little too much (perhaps) but if it is won't do no harm with some spare. ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Whee you using the stone chip just under the arches?
| SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527
Steve Did you get this from Rejel as they should supply DINITROL 445 500ml AEROSOL BLACK Stonechip Simon |
Sphere - Yes, but probably only the rear the fronts plastic is no point doing IMO but the rears certainly.
SGH (Simon) - Yep, from Rejel. I got some of the items in separate orders so it isn't a "kit" but more a built up kit. I bought the Autotek stonechip first before I knew Rejel did it and also I've had Autotek acid etch primer before with great results so I thought I'd stick with that. Ultimately it will be covered up anyway. The Dititrol stonechip is also a bit more expensive of which as it'll be waxed over anyway I'm not fussed. All personal choices really. I trust both brand names. ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Finished cleaning it a while ago. Done the Kurust stage today what I intend to do. Tomorrow stonechip hopefully.
Got a 3m paint mask too (may as well it's a confined space) ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Done the stonechip stage today after masking off. Pity the weather wasn't a bit brighter though. Had to get a work light to see properly.
Click image to enlarge Click image to enlarge Click image to enlarge ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
Very nice a Steve, but for the wax you need an Indiana Jones hat
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Dinitrol waxing done & what a messy job it is to do too.
Looking good steve, I'm currently trying to find paper suits in size chunky in prep for doing mine.
Did you mask off the bolt heads/drain plugs, or don't you think it'll stop you undoing them in the future? |
| All times are GMT |
