![]() | Home > Puma (Tdci) > Would like a "DPF - is regenerating" - light in th |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2249 ![]() ![]() |
Regen is every 400 miles for me and operates at 890 degrees .
landybehr Member Since: 17 Apr 2013 Location: -D- Posts: 173 ![]() |
I thinks that is what the workshop manual tells me too. But in real conditions it could happen that at mile 400 the regeneration starts but cannot be completed, because you shut off the engine at mile 403. Next day you go shopping, once the engine is warm enough and youīre driving fast enough it starts again. Before itīs completed you arrived and shut the engine off again. On the way home same thing happens. So there are 2-3 attemps and then one completed regeneration. And the more regen the more diesel in the engine oil. Iīd like any sign of "recognition" that the vehicle just tries to regen, |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
hello,
even if no problem until today, I would also be interested to know when it happen for the same reason as descripted by landybehr Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 462 ![]() ![]() ![]() |
Can soneone explain why the regen process might add diesel to the oil? Thanks,
John. 2.2 90 XS 88" Series One Old Norton ![]() Minerva |
Regeneration means that the exhaust gas temperatures shall be raised. This because with normal driving the exhaust gas isnīt necessarily hot enough to burn the filtred particles and thus not allways passively clean the filter.
To do so there is additional Diesel injected after the "main bang" in the cylinder already has taken place. Kind of "afterburner". IIRC the fuel consumption raises to twice the usual amount in this condition. Itīs only small amount of Diesel that is washed away from the cylinder walls by the piston rings and then finds itīs way into the oil sump. But one adds to the other ... The Dealer just changed the oil of my Dender today. Oil level is now right in the middle of the "XXXXX" mark on the dipstick. Yesterday it has been, say, 2-3mm above the max-level-mark. I donīt know how much the difference between min. to max. means. If it is 1litre then I guess there was 3/4l Diesel in the oil = 10% |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 ![]() ![]() ![]() |
Same here, though I don't have a DPF in the Defender but have one in the Freelander, but no light their either.
Used to have some issues with which could have been prevented if I knew it did not regenerate often enough. Luckely solved since then. |
OK, I am not a mechanic but can follow the principle behind the regen programme. Well sort of.
OK can understand that some diesel might enter the oil. My question would be how much diesel would be required in the oil to cause problems? Does diesel in engine oil actually cause problems? OK can understand that contamination in general is not a good idea. Brendan |
gbmud Member Since: 02 Jun 2013 Location: Sussex, UK Posts: 167 ![]() ![]() |
How do you know when it is regenerating? Chris |
Would be interested in the answer, too.
I read that some people can hear the regen. when it happens. That certainly is not true for me - the Defender is too noisy, resp. the MT tyres are. And/or my ears are too bad. Anyway, I cannot perceive anything. A friend who is a mechanic for Audi/VW, once drove an Audi and noticed a hesitation at acceleration/driving. Though Audi claims the driver wouldnīt be bothered by anything related to the regen. |
Good question - never felt any difference when driving along that I could attribute to the regen but then I have never been certain when it is actually operating!
Would one of the aftermarket OBD readers be able to indicate this? |
Say .. wouldnīt a EGT (exhaust gas) temperature gauge help in the matter ?
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 ![]() ![]() ![]() |
I have a PLX Kiwi2 WiFi ODB2 connected to the ODB2 port and clearly see it on my iPhone App. That is fine with me. Never forget: cars have owner, Landrover have field service personnel.
Unnecessary quote removed
What info are you getting/looking at to say the DPF is regenerating? |
Landybehr, we meet again, common interest in this measurement I see.
Ninety Td4, can you translate all those acronyms into simple english so we have some idea what you're talking about? Thanks, John. 2.2 90 XS 88" Series One Old Norton ![]() Minerva |
