![]() | Home > Maintenance & Modifications > Gearbox Oil Supprise.... |
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
Not sure on a LT77S gearbox but i once owned a RRC (or two) and the selector forks were held on the selector shaft by roll pins about 3mm diameter.
I had one snap one day and had to replace it and dropped the new one into the gearbox and never got it out ! If your gearbox is all working OK i wouldnt worry about it. IIRC the LT77 gearbox does run ATF. 2005 Td5 90 XS Steve |
| Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2418
ATF is the correct oil for an LT77.
| pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489
The LT77S is a completely different gearbox to the LT77 though, more of an experimental R380.
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
They were originally spec'd with ATF but found that it was liable to overheating and couldn't take the pressures put through it so rover came up with MTF94 which is higher viscosity and could take the higher pressure.
If your just cruising around with no real weight its not a problem but when your doing heavier work or towing there is a greater chance of it overheating. The Haynes book of suggestions says use ATF fluid but every Land Lover mechanic I have ever spoken to has recommended using MTF94. The only reason it had ATF in it was because I had to do an emergency oil change on holiday and it was all I could find as someone had previously filled it with ATF before I had it Just a bit dubious about the missing roll pin, but its a hell of a pain to dig out the gearbox to find out what the risk is. |
| All times are GMT |
