Home > Maintenance & Modifications > How many Dinitrol cans?
Page 1 of 3 123>
Dinitrol is available in 500ml aerosol cans which is good via their site or E-bay store. My question is how many will I require on a 90 Puma? I will be doing pretty much everything under there except the bits that obviously must not be.
Info much appreciated.
Oh and photo's too if you have any completed. Wink _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #259413 17th Aug 2013 5:06pm
mattlab
England 2009 Defender 110 Puma 2.4 USW Galway Green
just done my 110, bought the large car kit, 10 cans underbody sealer and 7 cans cavity wax, i put plenty on and filled the chassis till it was dripping out everywhere, i had 1/2 can of the sealer left over and 1 can of cavity wax, i sprayed everything except obviously prop, exhaust, engine, brakes. as per zagatos instructions i did the sealer first then the cavity wax as it drips everywhere, kept a can of the sealer back to spray over where the cavity wax runs down the chassis, as its brown. hopefully that will give you some idea until someone with a 90 comes along Thumbs Up LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE
Post #259436 17th Aug 2013 6:46pm
Just a little less then I'd imagine. Smile What sort of finish does the underseal leave a black waxy finish? _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #259485 17th Aug 2013 10:13pm
mattlab
yes, leaves a matt black hardish/rubbery finish but apparrently stays soft underneath, it looks like its just been painted matt black, the spray cans have a nice spray nozzle on them and buy the gun adapter for the top of the can. it saves that spray can finger syndrome and its only a few quid,
looks very nice and how it should look from the factory, i had wanted to do mine for a year and was concerned how it would look but now i`ve done it i would highly recommend it, and dont worry about getting runs in it as they soon dissappear, i got a few and came back to them a bit later and they had blended in Thumbs Up
i parked mine on a big plastic sheet on my grass as the cavity wax does make a mess but the underbody sealer hardly makes any mess at all, i did wear overalls but no gloves/mask/hard hat or condom. !!!!!!!!!!
any overspray wipes off with WD40.
i`ll try and get some pictures tomorrow. LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE
Post #259493 17th Aug 2013 10:45pm
Thank-you for the reply some really useful info there. Very Happy
Pictures would be great if you get the chance.
I was also going to stone chip it too before all this, after all I have cleaned the lot too perfection nearly so I may as well finish what I started properly. Very Happy _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #259500 17th Aug 2013 11:08pm
mattlab
good idea, i had`nt thought about that until i read another forum member said he had done his axles and wheel arches, but as id decided to do mine the next day(having had the kit sitting in the garage for a month) i did`nt have time to buy any, but ill see how mine fairs over the coming months LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE
Post #259503 17th Aug 2013 11:17pm
It shouldn't make too much difference but it's an extra layer of protection and something good forthe wax to cling onto. The couple of light rusty areas I'm going to clean up and Kurust first. So it will have been: Fully cleaned, dried out, rust areas cleaned and Kurust applied, stone chipped, chassis waxed, internals waxed.
And plenty of masking too I expect. If this weather sorts it's self out. Sad _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #259566 18th Aug 2013 10:00am
mattlab
Sorry not the best photos LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE
Post #259589 18th Aug 2013 11:08am
That's excellent. Thank-you for doing that. I've just wrestled my clamp on diff guards off to give it a clean up too. Probably get QT's at some point but either way they had to come off.m I'll also have the springs to do as well. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #259597 18th Aug 2013 11:57am
mattlab
not sure why their sideways, i loaded straight from my phone which i was holding upright ???????????? the finish looks a lot better in the flesh,
i also got away with hardly any masking up as the can spray is fairly accurate, LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE
Post #259618 18th Aug 2013 2:32pm
That's good. Thumbs Up
I took off my diff guards today to do a proper clean up and they'll stay of for now. All bar the wheel arches (mainly the rears) I have cleaned and de-greased the lot. Smile
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #259640 18th Aug 2013 4:51pm
GUM97
^^Looks good mate! Not bad at all for nearly 6 years old! Thumbs Up An engine to TDi for!
Post #259642 18th Aug 2013 5:19pm
Nope, not been treated either. Mind you I do look after her well. Mr. Green _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #259645 18th Aug 2013 5:21pm
GUM97
It's called Zag Syndrome Mr. Green Whistle An engine to TDi for!
Post #259647 18th Aug 2013 5:22pm
Well at least it's not painted White. Whistle _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #259650 18th Aug 2013 5:36pm
Page 1 of 3 123>
