Home > Maintenance & Modifications > usb in dash board
Caterham
usb in dash board
guys - thinking about fitting one of these -
http://www.mobilecentre.co.uk/index.php?ma...cts_id=653
and I'm wondering what wiring needs to be done ie crimps, soldering etc
and how much dash board needs to come out.
I'm looking at doing this while I'm away on holiday and therefore need to know what tools etc I'm going to need Very Happy
many thanks.
Post #258535 14th Aug 2013 6:56am
mobilecentre
If you replace the OE cigar lighter socket then it will plug in using the original crimps if you release them with a small screwdriver from their plastic housing.
The hole should be the right size or 0.5mm too small so a little rub with a round file should sort that.
Post #258545 14th Aug 2013 7:30am
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
I have been looking at the same but in the place for the headlight adjustment on my td5 dash would the plate at fit the whole square recess?
Post #258560 14th Aug 2013 8:11am
mobilecentre
The product page on our site is http://www.mobilecentre.co.uk/index.php?ma...cts_id=653 showing the various states of "undress" that can be used to fit it with or without the plate
we have a picture of it in a Puma dash and a dimensioned drawing as below
I do not know if the plate would cover / fit that recess you have
Post #258564 14th Aug 2013 8:34am
iPints
United States 1994 Defender 90 300 Tdi CSW Epsom Green
Mine looks nice and neat on the dash.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  The fear of death is the most unjustified of all fears, for there's no risk of accident for someone who's dead.
Albert Einstein
Post #258614 14th Aug 2013 12:37pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Yes it does, but it requires you to destroy the hole where the headlight switch went. I'll post a pic of mine.
Post #258660 14th Aug 2013 4:46pm
appaloosadude
Excuse the mess!
Post #258699 14th Aug 2013 8:18pm
Bev
Scotland 2003 Defender 90 Td5 CSW Oslo Blue
this is exactly the method I used and it took 20 minutes start to finish and provides almost an OEM look. Who actually uses the cigar lighter these days anyway. Other than to plug a power adaptor in to? Might as well replace this first !
You can always return it to original at a later date if required with no cutting of holes in the dashboard..
Post #258728 14th Aug 2013 10:33pm
