![]() | Home > In Car Electronics > Improved sound from standard speaker locations? |
doh,my bad!
nickh90 Member Since: 19 Oct 2009 Location: Nr Horsham Posts: 196 ![]() ![]() ![]() |
What did you do??
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2026 ![]() ![]() ![]() |
it makes a huge difference covering the tweeters on the dash with your hand, i have a function on my new head unit to turn the tweeters down, the speakers under the dash are pretty good really, give it a try and cover both tweeters
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
you have a v8, why would you need a radio?
![]() does your head unit have a treble and bass control function? (or even a graphic equilizer) then lower the treble in increase the bass if you don't fit the sub. After you fit the sub this may have to be totally reversed by upping the treble setting and lowering the bass setting to compensate for the sub doing its job and to get a balanced sounding audio system. hope this helps |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20942 ![]() ![]() |
As above. Most Head Units have this function.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1454 ![]() ![]() ![]() |
Boxes is the only way I'm afraid.
