![]() | Home > In Car Electronics > Tweeters in a 300TDI?? |
cabell Member Since: 20 Dec 2010 Location: Virginia, USA Posts: 33 ![]() ![]() |
Are the land rover tweeters used in conjunction with the same old coaxial speakers they have used for years or did they go to a typical component setup with a dedicated woofer / midrange for the pumas?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
Macpaul - Or you could always use a right angle drill chuck thing (what ever you call it.
![]() Cabell - IIRC as standard on the Puma it's component the standard speakers are mid range and the Tweeters have in-built X over's. They aren't the worst OE fit speakers I've known but when they get turned up a bit they've had it! If you had an aftermarket HU running on standard speakers I doubt they would last too long before they started to distort! ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1455 ![]() ![]() ![]() |
I managed to do mine in-situ. Drilled a pilot hole for holesaw. Then used just the holesaw, and turned by hand to keep square and tidy through the vinyl covering. Once through, and down to metal, I cleaned it all off, and then put the holesaw in the drill. It was at a bit of an angle, but as long as ii was through the covering, it could be a bit messy. Drill it out and a bit of fettering with a file and job done. ![]() If you need a hand Ipints Give me a shout ![]() Oh and I didn't realize that the crossovers were built in in the puma tweeters Steve |
iPints Member Since: 15 Jun 2012 Location: SC Posts: 294 ![]() ![]() ![]() |
Cheers fellas.......this is what makes this forum awesome....advice, help and everything.
I may take you up on the offer Jim....been looking at replacement dash tops and fancy doing something different.....maybe a recover in a different material.... The fear of death is the most unjustified of all fears, for there's no risk of accident for someone who's dead. Albert Einstein |
Got the tweeters, many thanks Steve.....
Not sure when I will get a chance to fit them......as I am off to Asia for a few weeks and then the US for a few more weeks....life is such a chore at times... ![]() ![]() ![]() Albert Einstein |
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
