Home > Maintenance & Modifications > Acoustic Mat
Tom DCab
United Kingdom 2003 Defender 110 Td5 DCPU Oslo Blue
Acoustic Mat
Hi All,
I've decided that I don't want to spend £450 on acoustic matting!
Has anyone found / fitted any other readily available products that can be cut by hand and will do the job instead of the £450 version?
Tom
Post #258352 13th Aug 2013 9:08am
theorangebandit
http://www.ebay.co.uk/sch/i.html?_from=R40...amp;_rdc=1
i dont rate acoustic matting if its cut to fit, so i used a roll of rubber matting and cut that to fit my last 4x4. the thicker teh better yet the thin stuf hugs shape better, get some good quality spray glue and your sorted
Post #258355 13th Aug 2013 9:36am
Discharge
United Arab Emirates 2011 Defender 110 Puma 2.4 DCPU Alpine White
I take it you've seen this: http://www.defender2.net/forum/topic17772.html
Should cost less than £300 from them? 2011 - 110 - Double-cab pick-up
Post #258356 13th Aug 2013 9:40am
Another vote for MPS and the Dynamat system Thumbs Up
You don't have to cover 100% of the panels, give Simon at MPS a ring for advice
Post #258358 13th Aug 2013 9:45am
theorangebandit
think we need to establish what your tying to cover ? just the load bay ? im hard saving for sound deadning ill be focusing on the roof and load bay first then as birthdays come around ill finish the job by doing the remaining floor and the doors and side panels
Post #258361 13th Aug 2013 9:53am
Tom DCab
As I have a Dcab im not too worried about rear tub.It would be for interior of cab, probably not roof and doors though..
I have had look at the link you sent to the previous post on Dynamat....Everyone seems to be buying it!
Not cheap stuff though....but then maybe I wont need to much of it.....
Can carpets go back down on top of it does anyone know?
Post #258378 13th Aug 2013 11:30am
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
It's pretty thin stuff, so carpets shouldn't be a problem.
Silent coat is the same sutff, but a lot cheaper.
Post #258379 13th Aug 2013 11:41am
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
I have just done the front of mine in dynamat with the wright off road mat on top. Reduced the sound by 8db (iPhone app) big diffrence. Such a diffrence I want to do the rear seats as well. I bought a 8x4 sheet of matting from wright off road to put over the dynamat in the rear just need to find some cash for the dynamat think it was around £125 guess you could do that for the front. Defentaly dynamat though Thumbs Up
Post #258388 13th Aug 2013 12:41pm
theorangebandit
you got a link to the matting you used ? and how much dynamat did you need for the front flooring ?
Post #258389 13th Aug 2013 12:54pm
Sphere
I used the moulded matting for the front. Expensive but worth it as gives a tidy finish with no carpets to get wet and muddy. I got my moulded stuff off ebay but the flat sheet from drew at wright off road (he does the molded as well) very helpful guy and gave me a copy of a land rover monthly article on fitting.
http://www.wrightoffroad.com/products.htm
I ended up using a bulk pack for the front with one sheet left over thinking I will need another for the rear
Post #258392 13th Aug 2013 12:59pm
theorangebandit
cheers for the info hopefully its helpful for the OP lol. im looking at the moulded mat for te front im just trying to find a company that does a cmplete front to rear moulded mat for the 110
Post #258393 13th Aug 2013 1:01pm
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
Re: Acoustic Mat
Tom DCab wrote:
Hi All,
Tom
are you sure that you need 450 for d-cab ? Confused
http://www.noisekillergb.com/product_details.asp?ItemID=104 www.newfoundland.gr
Post #258515 14th Aug 2013 5:50am
