Home > eBay & Bargain Spots > eBay - Axel Stands and 2 Tonne Trolley Jack - Any good?
Jim_Bean
I'm looking for a decent trolley jack and a couple of axel stands. Is this a good deal or should I go for something better?
http://www.ebay.co.uk/itm/3-Ton-Axle-Stand...35c943a3f2
Is this better?
http://www.ebay.co.uk/itm/2-Ton-Trolley-Ja...2a2c749812
Post #258101 12th Aug 2013 11:01am
landy andy
Think I would spend more and get better quality if it was me.
Andy
Post #258102 12th Aug 2013 11:07am
Jim_Bean
Any pointers? I'd like to get the stands and jack soon so I can get some Dinitrol under there before winter. Any suggestions would be welcome.
Post #258107 12th Aug 2013 11:15am
WarPig
Halforda sometimes have their 4x4 trolley jack on offer, which is where I got mine. Some standard jacks might not lift high enough for purpose. Or get a Disco/Defender bottle jack?
Post #258118 12th Aug 2013 11:28am
Jim_Bean
I just found this...
http://www.halfords.com/webapp/wcs/stores/...yId_255207
Seems like a great deal BUT the jack and stands are rated at 2 tonnes. Is that enough for a 110??
Still, looks a great deal!
Post #258122 12th Aug 2013 11:30am
landy andy
Yes they are good enough, as will only be taking half the weight of the defender at any time.
Is more what I would go for.
Andy
Post #258125 12th Aug 2013 11:36am
By coincidence, I came to use my Halfords 2 tonne jack yesterday (the same one as in that set) and the damn seal failed, so it just pumped out hydraulic fluid. It's a few years old but has only had light use, so I'm a bit disappointed. By comparison, I also have a much older 1.5 tonne Halfords jack that is still perfect - it just doesn't lift as high. ISTR that one came with spare seals too, although I've no idea where they are now Rolling Eyes
I doubt I can get new seals, which is a real shame as it renders the whole jack useless, so I'll probably end up replacing it with THIS 2.5 TONNE ONE. Darren
Post #258128 12th Aug 2013 11:49am
johnnyd
There's a bottle jack offer around somewhere, do you specifically want a trolley ?
here it is....
http://www.defender2.net/forum/topic21755....ottle+jack
http://www.ebay.co.uk/itm/261145375799
JD 2008 TDCi 2.4 XS CSW
Post #258129 12th Aug 2013 11:50am
WarPig
I've got the Halfords one in LRA's post. The only negative is it didn't come with a carry case. I must try and find one somewhere.
Post #258151 12th Aug 2013 1:34pm
excossack
Here's two options from Machine Mart
Trolley Jacks
http://www.machinemart.co.uk/shop/product/...olley+jack
Or
http://www.machinemart.co.uk/shop/product/...l-garage-j
Axle stands
3 Tonne (1.5t each?)
http://www.machinemart.co.uk/shop/product/...axle+stand
6 Tonne
http://www.machinemart.co.uk/shop/product/...axle+stand 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #258152 12th Aug 2013 1:39pm
WarPig
I've got the Machine Mart 3tonne axel stands and they work fine. Saying that, I've only ever tried supporting one corner of my LR at a time.
How do folk here use their axel stands for simple tasks such as changing wheels etc? Do you lower the jack so the stands take the weight, or just have them there in case the jack fails?
Post #258191 12th Aug 2013 4:20pm
leeds
I have tried two of the 2 tonne trolley jacks from Machine Mart. First one went back and was exchanged. Second one I can not remember what happened to it but it was replaced by a 3 tonne trolley jack from Difflock made in Germany. Much superior to the Machine Mart ones.
Best to have two means of support rather then one.
Brendan
Post #258217 12th Aug 2013 5:57pm
excossack
If I am doing a quick swap then up with Jack off with tyre and on with new one (like doing a flat at the road side) if its longer than that, up with jack, under with stand, down with jack onto the stand and wheel off. 1999 Defender TD5 110
Regards
John M0VAZ
Post #258226 12th Aug 2013 7:03pm
jimbob7
I got Silverline 3 ton ratchet axle stands off Amazon,they are pretty much a generic axle stand that can be bought anywhere for around £15,I really like them,you can also get the same generic ratchet axle stands in Cost-co fer about £15.
As for a jack I use a 10 ton+ bottle jack ( freebie I found inna skip,oh happy dayz!)I'd previously bought a 4-5 ton bottle jack which I am happy with, but you NEED axle stands when using bottle jacks coz they are not as stable as trolley jack.
If I get a trolley jack one of these is on mi list, they seem to get quite good reviews.
http://www.ebay.co.uk/itm/171028680739?ssP...1438.l2649
Or the more expensive generic aluminum "racing" trolley jack,google it.
Post #259082 16th Aug 2013 10:30am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
jimbob7 wrote:
... but you NEED axle stands when using bottle jacks coz they are not as stable as trolley jack.
I'd recommend axle stands with a trolley jack too, as above, the seals can fail. I use axle stands and put a wheel underneath if I can, better safe than sorry.
You don't want to be a candidate for the Darwin Awards...Wink
cheers
simon
PS: I got the jack and stands from Costco, from the reviews I checked they are solid and rated for 3 tonnes. Often stands are rated per pair too, so check the rating for a single stand
Post #259084 16th Aug 2013 10:39am
