![]() | Home > Maintenance & Modifications > Lost a Mud Flap |
http://4x4overlander.com/entreq-products/e...ckets.html
![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
not sure thats what im needing, the whole bracket has been taken clean off, he flap itself is still very attached to the arm lol
infact on second looking that looks like its meant to reinforce the lip of the arch am i correct ?
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2139 ![]() ![]() ![]() |
![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
i am buying them bad boys !
thanks for the find bob neville thread closed lol |
Cat81 Member Since: 05 Mar 2014 Location: Kent Posts: 60 ![]() ![]() ![]() |
I just lost my 2 rear mudflaps (!) to the same issue. Wheel arch broke at the fixation point. This looks like a great solution although I am now worried to tear the whole thing apart.
Is it possible to fix 90 mud flaps to a 110 (the ones that go on the cross member)? |
Yes I would think it is possible to fit 90 rear mud flap brackets to a 110.
However because the rear mud flaps are now set back further then normal they may well not control water spray so effectively on a wet road. It may be a better idea to use the strengthening/repair brackets on the body panel and drill a small hole in the bottom of the rear mud flaps and attach a baby shackle etc and just tie the rear mud flaps up onto rear bumperettes etc. when going offroad. Brendan |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5939 ![]() ![]() |
Or buy Gwyn Lewis reinforced quick removal mud flaps. That's my plan.
http://www.gwynlewis4x4.co.uk/product/defe...quare-tub/ Andy |
Thanks Brendan that sounds like a plan. Andy, these are nice, but also ... 100+ quid!
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Happens the same to me several years ago.
1st try to straighten the tab were the mudflap is attached. Buy a L shape 20x20x1 mm aluminium, cut in a +/- 150 mm long make an hole to put again the bolt and rivet or bolt it to the tab of the panel in 4 points. 1/2 hour work. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
