![]() | Home > Maintenance & Modifications > Battery controller? |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
looks like complete rubbish to me.....
![]() ![]() how many amps is it rated for? continuous and momentary etc. a lot of these cheap battery controllers are not rated to put up with the loads which land rovers get. also.. if you just want to stop your battery draining you could fit a simple isolator like the ones from blue sea? |
Not sure about that particular make but these are used widely in the haulage industry etc where it would be extremely costly if a vehicle were left stranded with a flat battery.
A manual system is only OK if you remember to use it ! |
This is my battery controller... keeps it filled to the brim, no matter how long it stands unused....
![]() ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Not the same thing Eric.
The OP has posted up a device that will stop the battery going flat if you left the lights on for example whilst parked in an airport car park whilst on holiday. |
Correct, I did understand so much....
![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
