Home > Td5 > Speedo bulb change
Roy l
United Kingdom 2000 Defender 110 Td5 XS DCPU Epsom Green
Speedo bulb change
Apologies for announcing my arrival with what is probably a ridiculous question BUT, I have recently purchased a 2000 TD5 and am going through the vehicle doing repairs including replacing blown bulbs.
I changed the bulbs on the smaller gauges (fuel etc) with ease by removing the bulb holders and replacing them, but in attempting to change the speedo bulb, i was thrown as there is no bulb holder or wires plugged in to the back of the bulbs. I have trawled all the Land Rover forums before embarrassing myself......but shouldn't there be wires plugging in to the two bulbs??? Shocked
I have the replacement bulbs ready to go and appreciate that I will meet difficulty in withdrawing the blown ones, but the lack of wiring is confusing me.
Thanks Defender Virgin - go gentle with me!
Post #257151 8th Aug 2013 12:23am
dorstsmith2
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
Post #257172 8th Aug 2013 7:58am
excossack
The bulbs are sunk into the speedo, If you get a long pair of decent tweezers you can grip the flat sides of the bulb and twist them to remove the bulbs. You should then see some contacts on the holder.
Have a shuffties at the link above for more info. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #257176 8th Aug 2013 8:24am
Roy l
Thank you very much for clearing this up. Very Happy Defender Virgin - go gentle with me!
Post #257194 8th Aug 2013 10:12am
Peter
United Kingdom 2005 Defender 90 Td5 SW Epsom Green
If you have not got tweezers these are cheap and much stronger and work perfectly
Ebay item eBay Item No. 271175281787
Peter.
Post #315402 12th Mar 2014 2:33am
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
I attacked an old pair of long nosed pliers with a grinder in order to reduce them in size to something small enough to fit
Post #315413 12th Mar 2014 8:18am
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Those mini long nose pliers look a great idea.
I did this job earlier in the week and it's a bloody fiddly job even with tweezers. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #315426 12th Mar 2014 9:32am
Peter
Had bought another Def TD5 speedo cluster a few years back ( was going to put on'87 90) have a spare to play with. Takes about 10 seconds to change one of the bulbs after a trial run.
Am now awaiting new SMD LED's hope they fit eBay eBay Item No. 161034467304.
As its so easy to fit might get some red ones for winter driving, or a set for spare speedo.
Can't believe I don't read my old posts... http://www.defender2.net/forum/topic12373.html
Socket seems sensible!
Peter
Kent LRC.
Post #315604 13th Mar 2014 1:49am
rich
England 2004 Defender 90 2.5 TD HT Barolo Black
I have just replaced the works td5 bulbs myself with some lovely blue led bulbs
a bit sad but I quite lke them
Post #315608 13th Mar 2014 7:58am
