Home > Puma (Tdci) > Heater
vogue se
Belgium 2011 Defender 90 Puma 2.4 Exclusive HT Nara Bronze
Heater
I discovered a difference in heating temperture between the left hand sight and the right hand sight.
Def went into LR workshop but they couldn't find the mistery. Anybody with teh same experience...and a solution?
Thanks.
Pieter
Post #8496 16th Mar 2009 6:54pm
Anvil
Italy 2008 Defender 90 Puma 2.4 CSW Tonga Green
Hi vogue
Yes this is a known (not well Very Happy ) random problem for the LH models.
There is a bullettin that explains how to fix it - SSM39653
I can't find it in the GTR's english section (obviously Laughing ) but you can find it in dutch or french, anyway the fixing procedure is attached as an external document (in english)
Some friends here in italy faced this problem but I don't know if someone tried to fix it on its own because a sort of a seal it's required.
Post #8502 16th Mar 2009 10:46pm
shingwell
It's a problem for RH models too.
I took mine back to the dealer for this reason (my Mrs gets cold quicker than me and as hers is the cold side, it was causing problems!)
They measured several other vehicles and they all read 2C colder on the LH side than the RH side - no fix offered.
Post #8517 17th Mar 2009 10:55am
one_iota
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
I suffer constant complaints from the passengers front and rear. Rolling Eyes I am constantly asked to turn down the airconditioning.
I have a theory based on the right hand drive version:
The warm air from the engine bay (and it gets quite hot) finds its way into the drivers side via the hand brake hole.
Who would ever have thought that this would be an issue in a Defender. Mahn
'08 Defender 110
ex '95 Disco 300 Tdi
www.aulro.com
Post #8519 17th Mar 2009 11:16am
Anvil
Here is it
http://rapidshare.com/files/210802251/Heater_fix.pdf.html
link updated
Post #8533 17th Mar 2009 3:13pm
vogue se
Many thanks for the reply. Bow down Thumbs Up
I can't find the GTR section but no problem. I check it at the dealer.
Post #8580 18th Mar 2009 6:55pm
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
The file attached in the link above is not available, can someone send to me a copy?
Thanks!! Matteo
Defender 110 Td4 SE MY 09
Post #17086 23rd Oct 2009 9:51am
Anvil
The uploaded file seems to be unavailable
here is a new one
http://rapidshare.com/files/297726421/Heater_fix.pdf.html
Post #17193 25th Oct 2009 4:02pm
WinBoot
Belgium
Could anyone reupload this? Cant find it anywhere and my passengers are complaining heavily from cold
Post #25711 3rd Mar 2010 3:56pm
peanutbob
I think you will need to refer back to the original Puma Test Files. A realisation occurred in Tromso, I think, that there was a need to keep the driver warm in sub zero conditions, whereas a culled Reindeer or Moose (in Canada) left in the rear of the vehicle or even in the passenger area would suffer from heat on a long drive back to the lodge. So, this was inbuilt at the time, and very effective it is too!
Post #25738 3rd Mar 2010 11:31pm
dgardel
Italy
Anvil wrote:
Hi vogue
My dealer done the job on my Defender in february 2009 and, now, it works great!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #25748 4th Mar 2010 12:13am
Anvil
Hi Guyz
I've just re-submitted the pdf
http://rapidshare.com/files/363668798/Heater_fix.pdf.html
Post #26882 15th Mar 2010 3:35pm
Martin
Site Admin
Added to the Defender2 gallery so it won't be deleted from elsewhere, and no annoying waiting: http://www.defender2.co.uk/gallery/albums/...er_fix.pdf
Post #26887 15th Mar 2010 4:26pm
Anvil
Great ! Thumbs Up
Post #26896 15th Mar 2010 4:54pm
