Home > Maintenance & Modifications > Epic Mot Failure....Help?
Page 2 of 2 <12
TD5_dan
2001 Defender 110 Td5 CSW Java Black
Thumbs Up Clive knows every section of a standard crossmember and has designed a new version that does not trap the water so will outlast the rest of your chassis. Laughing 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon
1970 Series 2A hard top
1960 Series 2
1972 Series 3
Post #256875 6th Aug 2013 10:10pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
Another vote for Clive (have a look in my gallery) I work at a welding and fabricating company so I've seen lots of welding and Clive's is amongst the best Thumbs Up
Post #256885 6th Aug 2013 10:36pm
Mean Green
If there is any way you can afford to do the galv swap seriously consider it - especially if you are planning to keep the LR for a while. I had exactly the same issue a few years ago - at the time the choice was £120 for a crossmember or £1200 for a chassis. I went for the cross member and have regretted it ever since. Yet again I have just shelled out £170 for some wleding for this years MOT - the galv chassis would have been well on its way to paying for itself.
I would say your garage are pricing themselves out of the job as they do not want to do it.
Post #256925 7th Aug 2013 9:25am
TD5_dan wrote:
Only place I would be going for a crossmember is here, end of!
Clive is a top bloke and you will not get a better crossmember anywhere in the UK
http://www.blacksheepoffroad.co.uk/Site/Products.html
Whereabouts is Black Sheep Offroad based? Seems a bit coy about this on the website.
Post #256973 7th Aug 2013 12:04pm
Happyoldgit
^^Essex. Steve.
http://forums.lr4x4.com
Post #256984 7th Aug 2013 1:02pm
abomb1969
United Kingdom 1998 Defender 110 Td5 CSW Santorini Black
Canvey Island
Post #256985 7th Aug 2013 1:09pm
shaggydog
On inspection this morning I was shocked to find what the extent of the damage..
Nearly a whole 5p coin size hole on the passenger side and a hole maybe the width of a pencil on the other.
Hardly worth replacing the WHOLE crossmember for...
So, deal was struck I'm going to plate it myself then return it for the retest and they are going to carry out the work on the swivels as there were no more shims to be removed unfortunately. The drop link also going to do myself as the part was £70 and the labour was £200, No brainer really.
Planning on plating over for the test to satisfy the Mot man and then later in the year if and when I get a chance I'll get it cut out and replaced properly then ether waxoiled or dinntroled to give it some protection.
As much as I'd like to have a galve chassis, it doesn't need it yet.
Will upload some photos when home
Post #256986 7th Aug 2013 1:13pm
pressbrake
United Kingdom 1990 Defender 110 Other SW Fuji White
Just saw this post, yes Im coy because Im not advertising where I may have my expensive tools and customers equally expensive defenders kept
Post #279815 5th Nov 2013 9:01pm
familymad
I third that 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #279838 5th Nov 2013 9:36pm
Page 2 of 2 <12
