![]() | Home > Maintenance & Modifications > Replacing rear capping |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767 ![]() ![]() |
Normal alloy rivets are fine, they are some of the few items that don't seem to suffer with corrosion.
Make sure you paint / treat all surfaces of the new capping before fitting. From the factory the capping is very poorly protected which is why it rusts, the underside is given just a quick blow-over before being fitted to the tub when the top-coat is applied. 12-Years ago I removed all my new capping and had it painted all over and then Waxoyled on the underside, a couple of years ago I removed it to have it galvanised and it was still like new. ONE LIFE, GET IT! |
Mine wasn't painted on the underside at all
![]() Basically, a case of drill out and replace rivets, and then paint and seal thoroughly! It does mean side panels and roof off though ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3409 ![]() ![]() |
Out of interest, I waslooking at doing the same job but ran the grinder over the capping with a sanding disc on and is almost as good as new (and I haven't had too lift the roof!)
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6005 ![]() ![]() ![]() |
Sorry my bad, I meant the vertical capping that goes from the xmember upto the capping below the window capping.Is this still roof off? 1999 Defender TD5 110
Ah, my bad
![]() ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Phew.......I did ponder using stainless dome head bolts and nylocs... But maybe some rivets will be easier.
Now. any idea of the size/length needed? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Not 100% sure of rivet size, I'd go and check the sizes for you that I used, but I'm on holiday
I'm sure I can find out what the are. Enjoy your holiday. 1999 Defender TD5 110
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17847 ![]() ![]() ![]() |
My 07 DC has galvanised cappings (painted body colour) and was clearly built linke that from new, although the tailgate capping is un-galvanised painted body colour.
I have a suspicion that vehicles that leave the factory with tilts have galvanised painted cappings, and those which leave with hardtops have cappings which are only painted, but this is only a suspicion. Has anyone else (with a TC or DC) found that their cappings are galvanised? |
The rivets that you want are blind rivets - so they don't let water in. These are the sort of thing:
http://www.ebay.co.uk/itm/Land-rover-defen...35bb6300ac Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Blind rivets thats the one! cheers. 1999 Defender TD5 110
Finally got around to replacing the rear capping on the 110 and while I was at it, I cleaned up the chequer plate on the rear and replaced the bolts with stainless hex heads.
Let the pictures speak for themselves. Old capping ![]() Click image to enlarge Old chequer plate & old bolts ![]() Click image to enlarge What lies beneath ![]() Click image to enlarge Off with the old ![]() Click image to enlarge Started the cleaning of the chequer plate ![]() Click image to enlarge Cleaned up (2nd time around. First time I thought it was cleaned and prepared enough, only to find when I applied the etch primer I could see bits of previous coating that had curled up a little so started again) ![]() Click image to enlarge Capping on and ready for rivets ![]() Click image to enlarge Chequer plate primed and almost ready ![]() Click image to enlarge Attached and ready for lights ![]() Click image to enlarge Chequer plate on with new stainless hex bolts ![]() Click image to enlarge Now I need to repaint the rear 1/4 panel, replace the decal as the old one has worn away. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Looks great
![]() Did you have to pre spray the rivets before fitting them? |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Nice job with good pics
![]() Steve |
