Home > In Car Electronics > Toughbook
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
Toughbook
I am looking to mount a toughbook in the front of the 110 to run sat nav and to have for emails, and possibly internet on the move. Maybe even have an external disc drive and run DVDs etc
I have seen some refurbished toughbooks on fleabay and wondered whether they were up to the job. Are they suitable or old ones which would not be much use for me
Here's an example link
http://www.ebay.co.uk/itm/TOUCHSCREEN-Pana...35c4ec5527
Any alternatives?
Dave
Post #256605 6th Aug 2013 2:48am
toughbooks are fine i have a cf18 with touch screen, but iPads etc are also a good cheaper alternative
Post #256613 6th Aug 2013 7:13am
jst
that will run MM or similar and emails. i have two similar spec to that for that exact use.
DVD's - now you are joking right? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #256620 6th Aug 2013 7:34am
jst
but not as robust! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #256621 6th Aug 2013 7:34am
jst
and without email you cant get anything off the bl**dy things.
typical example. we ran a MM route and marked it on a TB, TJ was running an IPad and couldnt get a copy of it without being online, difficult in the middle of no where. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #256622 6th Aug 2013 7:35am
Dell are selling a toughbook copy but a lot of mixed reviews
A Panasonic cf18 or cf19 is my preferred option for overlanding but dvds or anything processor intensive will be a challenge, great for nav apps and storing photos, doing emails etc
A reasonable all rounder for < £200 would be a refurbed IBM Levono T61, dual core, 2gb, 80gb disk, good build quality and as long as you keep the fans clear will run and run and run, and quick enough to run dvd's
Post #256628 6th Aug 2013 8:10am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Bluetooth should work, depends what you are needing to send it to I guess.
Edit: seems BT won't work for file transfers Sad
I use an iPad ( with 3G) and run mmap, Copilot, google maps, GPS motionX, and View Ranger...so have all eventualities covered..!
It's probably the most robust solution...I have it in a Griffin case and use a Ram mount. No moving parts to break and waterproof enough for even a Land Rover.. Very Happy
Simon
Post #256633 6th Aug 2013 8:26am
TJ101
Simon
BT did not work, sending a MM file from a CF18 to a I Pad !!!
I Had 2 CF18's, One bought new, and a ex BT unit (now BPman's )
Now rarely use the Toughbook, but its the more reliable unit, a bit heavy when mounted in a Ram Mount, and driving rought offroad, The I pad is better then due to the lighter weight
Screen is better on the I pad (IPad3) California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #256641 6th Aug 2013 9:08am
couplands
I always have the USB charge cable, so could use that with the laptop..?
Simon
Post #256644 6th Aug 2013 9:17am
theorangebandit
i have that very toughbook and its a brilliant little device for carrying all my computery type stuff for work lol not the fastest device but fantastic value
Post #256778 6th Aug 2013 7:13pm
jst
i have two cf18s, its probably time one went too. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #256785 6th Aug 2013 7:25pm
v8bobber
I wasn't aware that runnning DVDs might be a bit too much for one, just thought it would be handy for the kids in the back if they want to watch a film or something.
I can see from looking on Fleabay that they are a few hundred quid as opposed to the toughbook which was more like £100.
Would any of the other tablets do a similar job. I'm not up the various types hence the original post
Thanks
Dave
Post #256880 6th Aug 2013 10:24pm
BigWheels
You can buy tough shells for ipads etc. I have Otterbox Defender (!) for phones. They have both armour & silicon outer. For tablets you only need anti-shock mounting. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #257139 7th Aug 2013 11:38pm
TJ101
No amount of protection to a I Pad etc, will bring them up to the standard of a Panasonic Toughbook,
certainly not the treatment my CF18 has had ! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #257259 8th Aug 2013 2:06pm
And it's still going strong Thumbs Up
Post #257261 8th Aug 2013 2:08pm
