Home > Tdi > 300Tdi Oil.
djgg
300Tdi Oil.
Hi,
I`ve done a search, but cant find an answer, I have just got a Defender 300Tdi what grade of oil do I need when I do an oil change?
David.
Post #256201 4th Aug 2013 5:45pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Always ran mine on 5w30 semi synthetic,Bought it at 103,000 kept it till 160,000 (well it went walkabout actually).Never had any issues. 2005 Td5 90 XS
Steve
Post #256205 4th Aug 2013 5:56pm
Alex1976
I run my 300tdi on 10W40 Semi Synth (Fuchs Titan) and it seems fine as well as this is what is listed in the manual so should be ok. I think dropping to a 5W30 is ok too and may improve mpg etc.
Post #256207 4th Aug 2013 5:58pm
shaggydog
10W40 Part Synthetic.
Can go for the most expensive magnitech but its equally as happy on the cheap halfruads stuff.
Before you change give it a run with a tin of engine flush in it till it’s warm, then drop the old oil while it’s still a bit warm (it will look like a mix of oil and coal dust which is normal) remember to replace the sump sealing washer and oil filter then refill with new oil.
Up to you but I always add in a tin of Wynns oil treatment when I change as I feel it makes a difference to my engine's running but again, up to you.
Post #256209 4th Aug 2013 6:04pm
WarPig
I think Halfords are running an offer where all their oil is £10.
I recommend fitting a Drainplug to replace your sump plug, makes draining the oil so much easier. I got mine form Difflock...
http://www.difflock.com/drainplug/
Post #256216 4th Aug 2013 6:09pm
Litch
My 300TDi was filled with Magnatec by the main dealer at the initial 1K mile service and I have used the same stuff every 6-months since.
They also stripped the drain-plug at said service so I fitted a Difflock Drainplug the next time (wasn't letting them near it again) and it has worked fine for all these years. ONE LIFE, GET IT!
Post #256242 4th Aug 2013 7:23pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Whatever costco are flogging! Big drum (20l or so) for the price of one bottle from usual shops. Think it's 10w40
Being a tdi, it will probably run on anything.
Post #256325 5th Aug 2013 9:18am
Retroanaconda
I just use 10w/40 or 15w/40 semi-synthetic - whatever I can get hold of cheapest at the time.
If you look in the handbook it actually tells you what fluids to put in and when Wink
Post #256345 5th Aug 2013 10:28am
Alex1976
I popped into Halfords this morning as I needed a few bits and had a look at this oil. It is not their usual oil that is on sale, it is a 'special purchase' product. It is in 4L containers rather than their usual 5L and seems to be a cheap generic oil (petrol or diesel). The Halfords 10W40 turbo diesel specific oil is £17.99 for 5L.
I think I will stick with Fuchs Titan which I can get for about £18 for 5L from Opie as that is good quality stuff and not much more than Halfords.
Post #256366 5th Aug 2013 12:05pm
drewster
Wales 1997 Defender 90 300 Tdi CSW Epsom Green
Try Morris c three 10/40 I find it very good
Post #256410 5th Aug 2013 4:19pm
Martin
Site Admin
There is a discount at Opie for Defender2 members Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #256416 5th Aug 2013 4:39pm
djgg
Thank you all for your advice, one more question. I have 10ltrs of 15W40 multi purpose oil would this be ok to use? or do I need to buy some semi-synthetic oil?
David.
Post #256456 5th Aug 2013 8:03pm
Alex1976
Personally I would stick to a decent 10W40 rather than use up the stuff you already have, however tempting it is to save cash. However that is just me 'like things to be right' rather than a technical expert opinion.
Post #256477 5th Aug 2013 8:54pm
djgg
I think your right, decent 10W40 it is then, but it was worth asking.
David
Post #256485 5th Aug 2013 9:06pm
jst
Fuchs 10/40 Semi i run in my tgv's Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #256550 5th Aug 2013 10:09pm
