Home > Puma (Tdci) > Best-Easiest Cable Routing Dash To Front Bumper?
gprich
Wales 2012 Defender 110 Puma 2.2 USW Orkney Grey
Hi all,
With my 2012 defender puma 110xs usw - what's the quickest and best route to get a cable from the dashboard area to the front bumber area without any drilling etc. in other words where are there holes/groumets that can be used?
Thanks in advance.
Gareth.
Post #255981 3rd Aug 2013 5:26pm
K9F
Depends really how many cables and for what? If it's for lighting have you considered tapping off the relay and going out through the underseat box that has large grommets fitted and plenty of room, or tapping from the lights themselves and going into the same underseat box? Would also save dash dismantling. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #255984 3rd Aug 2013 5:46pm
gprich
Thanks for response, its just to run an external temp sensor, cables quite thin but sensor on the end of it is about 1" x .25".
Gareth.
Post #255985 3rd Aug 2013 6:06pm
I would go from the dash, through the back of the bulkhead into the engine compartment (does the puma have the same large oval rubber grommets like Td5?), then route the cable behind the brake cylinder, pick up on the RH wing wiring loom, and follow that path down to the front of the wing. You could mount the temp guage behind the louvre bit on the plastic headlight surround.
Post #255986 3rd Aug 2013 6:14pm
Cheshire110
when i fitted my DRLs (2010 110) i went:
from behind radio fascia,
through large oval grommet through bulkhead on passenger side,
over front wheel arch,
Into the headlamp 'box',
out the bottom of the headlamp box - under the bottom of the headlamp surround panels,
and straight into the back of the bumper Cheers, David
Post #255988 3rd Aug 2013 6:18pm
gprich
Thanks for that, I don't know whether the puma's have the same oval grommet as the TD5 I'll have to go and look unless someone comes up with the answer first Smile
Post #255989 3rd Aug 2013 6:19pm
Cheshire110
gprich wrote:
Thanks for that, I don't know weather the puma's have the same oval grommet as the TD5 I'll have to go and look inless someone comes up with the answer first Smile
yes they do (see my above post!) and there are also 4 smaller grommets which you can cut out around the outside which also works well, its a matter of which you can find with your finger inside the dash! Cheers, David
Post #255990 3rd Aug 2013 6:21pm
gprich
Thanks David that answers the question of the grommet as well. Very Happy
Gareth
Post #255991 3rd Aug 2013 6:22pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
I went thought the route of the ariel cable and used it to tape onto and pull through then just followed existing loom
Good luck It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #256080 3rd Aug 2013 10:21pm
