![]() | Home > Maintenance & Modifications > Brake pads change. (And what are you now using) |
| Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677
wheres the best place to purchase ebc green stuff? or anyone have the part number, cheers.
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21029
Dan @ Duckworth parts.
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
cheers, will give him a pm tonight once the garage has had a look
| WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748
I've recent had a full set of Paddocks High Performance drilled & slotted discs fitted, along with Greenstuff pads following geoblokes recent fitting.
Had a bit of an issue the other day on an all day trip, went down a very steep long hill. ( Porlock Hill) got down okay but brakes were smelling and had severe brake fade by the time I got to the bottom. Pretty much had to stop or go very slow for a while to let them cool obviously heat issue and only had this once, when new discs are required upgraded discs for cooling I think will be needed. What is the average service life of standard discs? ____\We|Will|Win/___
| Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767
I am running Mintex in both my 90 and my wife's Freelander and really like them.
Prevsiouly I was running Lucas pads in the 90 but didn't like them so they were replaced when they barely one third worn (I think the problem was that they were so hard that they WEREN'T wearing), the Freelander was still on the original pads but likewise, they were only half worn. In both cases, after the initial bedding in the braking has certainly improved over how it was and I will stick with Mintex from now on. Had Greentuff on my wife's MGF which she owned many years ago, seem to recall they were a nice pad. ONE LIFE, GET IT! |
Disc life depends on how they are worked, the minimum thickness should be cast into the disc somewhere but of course if a disc is marked / blued or cracked then it should be replaced but that is easy enough to do. How old is the fluid? Brake fade is not unknown, are yours solid or vented on the front? My 90 was originally solid but I upgraed to vented some time ago, not because I really needed to but just because I could. ONE LIFE, GET IT! |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
I used to use DS11 pads with the 4 pot calipers on my old MK2 RS, for some reason, not for road use but very little brake dust. Are these GreenStuff pads similar ? ie Low dust
Brake fluid is relatively fresh, solid standard discs on mine so I think it's an excess heat thing where vented discs would dissipate heat better the solid discs don't. Of course they were already warm anyway after running pretty much all day driving anyway. I must admit its a little worrying though when you brake and it's like braking on jelly. ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
BP - Cant say I've really noticed any dust, but they have cleaned and conditioned the disc surface though. Saying that the is probably likely to happen anyway. ____\We|Will|Win/___
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
I recently changed mine all round at 48k,still life in them but the calipers and pads were rotted and seized,if your on non vented it's fairly cheap to buy vented calipers (cheaper than non vented??),you will see a benefit.I greased the pistons with (plenty of) proper silicon grease when I fitted 4x new calipers. I used AP discs and pads (oem I believe),but not bought from the stealers. |
| All times are GMT |
