Home > Wheels & Tyres > tracking - wheels
Page 2 of 5 <12345>
mk1collector
Do the tracking AFTER you've put on the new tyres and had the wheels balanced or its a waste of money because most suspension/wheel/tyre changes have an effect on wheel alignment
Post #255552 2nd Aug 2013 8:46am
Happyoldgit
....but where did you get the tracking checked? If it was yer average High St tyre and exhaust place I wouldn't go jumping to conclusions that the rear end is out of alignment solely based on their judgement.
Can you post up some photos of the wear on all four? Steve.
http://forums.lr4x4.com
Post #255566 2nd Aug 2013 9:40am
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
A bit of string, or a suitable extending rod ideally, is all you really need to check the front tracking on a Defender.
Post #255568 2nd Aug 2013 9:53am
Caterham
you only need to check the front.....
so what if the rear is out?
Post #255573 2nd Aug 2013 10:35am
smb
The rear is just as important. You can usually tell if it is out by abnormal tyre wear(have a look at the edges of the tread to see if they are 'burring' over) and depending upon how out they are by following the car and you would see it driving at a slight angle. You would be quite surprised how many cars have their rear tracking out. You would also be quite shocked at the excessive wear on bearings, bushes, etc... that this causes
Post #255575 2nd Aug 2013 10:43am
Caterham
smb - the rear must be out due to the uneven wear, problem is I can't see how you adjust it?
Post #255583 2nd Aug 2013 11:16am
K9F
Take it to a professional.....You've already 'goosed' the handbrake. Thumbs Up Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #255588 2nd Aug 2013 11:23am
Diablo
so how do you 'track' a solid axle on a Defender?
Granted there is the tiniest bit of adjustment in the rear tie rods, but not tracking per se.
Post #255591 2nd Aug 2013 11:31am
mk1collector
As you don't have any equipment to correctly measure any of the geometry I suggest you leave it well alone. Replace any damaged tyres and balance the wheels then take it too a reputable garage (not the likes of kwik fit) and get a full 4 wheel alignment done with read outs that will show every measurement is within tolerance then you can relax as you will have the evidence in front of you that it's all straight so this can be ruled out of your future worries of which I'm sure there will be many. Thumbs Up
Ray
Post #255593 2nd Aug 2013 11:32am
K9F
"Having noticed a small dent in his rear offside door Caterham decided to try out his panel beating skills. After all how difficult could it be? The end result was not what he expected and a trip to the garage (again) was obviously on the cards!"
Rolling with laughter Bow down Rolling with laughter
Post #255594 2nd Aug 2013 11:36am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
You shouldn't say such things, he will be out now making sure the chassis isn't bent.
Rolling with laughter Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #255623 2nd Aug 2013 1:39pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Tracking on the rear of a Defender is fixed - it's a beam axle so unless you've bent your axle you can't have the tracking out on all 4 wheels. There is no adjustment for the rear and the fact that the garage you went to suggested there was shows they are not competent to correctly measure it.
The front can be adjusted but as others have said, take it to someone competent with Defenders as the vast majority of tyre places haven't a clue what they're doing when it comes to a Defender and alignment. They probably interpreted the offset in track between the front and rear as a problem when it's actually quite normal on a Defender. The laser alignment sets are the worst for this if incorrectly used.
You can also set the tracking up yourself at home with a bit of wire/string, at least close enough not to give uneven tyre wear problems. http://www.yorkshireoffroadclub.net/
Post #255626 2nd Aug 2013 2:11pm
Caterham
Laughing
so glad you're hear Mal......after what I've just been told I need some entertainment to lift my spirits.
would appear the tracking is in fact ok.
tread being stuck to tyre NO. apparently all the tread is lifting. Big Cry
and as much as I'd like to think the bloke is wrong I'm tending to completely agree.
off to phone continental now but would be very interested to know what you all think.
oh and by the way I'm thinking of writting a book and you're all stars in it. Very Happy
Post #255637 2nd Aug 2013 3:37pm
K9F
I would get a written opinion from a tyre specialist first to back you up perhaps? I think all the usual excuses will come out....."They must have been over inflated Sir!" etc. etc. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #255638 2nd Aug 2013 3:42pm
Caterham
just come off the phone to conti and sounds promising but the bad thing about this its likely to go down hill I guess.
oh joy.
anyone else had issues with the conti's.
just waiting for them to come back and tell me I've been driving too slowly Shocked
Post #255643 2nd Aug 2013 3:50pm
Page 2 of 5 <12345>
