Home > Technical > hand brake warning light and a grinding sound...
Likeomg
hand brake warning light comes on when on bumpy terrain or steep downhill's, also hearing a slight grinding sound coming from underneath, anyone experienced this / got ideas ? on a puma 90..
couldn't say if both happen at same time but grinding noticeable after the warning light starts flickering
Post #255425 1st Aug 2013 8:56pm
GUM97
Perhaps it's not fully releasing? Or reapplying slightly when on the bumpy terrain, causing the noise and the light? An engine to TDi for!
Post #255431 1st Aug 2013 9:06pm
Likeomg
partly my thinking, the car did sit for 5 months but i dont think the hand brake was left on...
Post #255433 1st Aug 2013 9:07pm
Porny
Site Sponsor
Re: hand brake warning light and a grinding sound...
Brake fluid low? - this puts the handbrake light on as well.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #255458 1st Aug 2013 10:10pm
As stated above, the same warning light is used for low fluid. Steep downgrades especially when braking may activate it as the fluid runs to the front of the reservoir.
If your pads are worn to bare metal you'll get a grinding noise, and the level will be low due to the piston extension in the calipers.
Post #255462 1st Aug 2013 10:17pm
Likeomg
cheers Thumbs Up
Post #255466 1st Aug 2013 10:21pm
jst
low fluid
handbrake cable too tight
sticking shoe combined with low fluid
pads shot
is the grinding noise only going down hill, only under braking or all the time? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #255524 2nd Aug 2013 7:10am
