I can't believe that the wire isn't soldered into that pin in the plug.... even the proper factory crimped plugs don't grip that well, let alone one that's clearly been done by a pair of pliers
I'd go right through that screen wiring loom of it were me, and check (and solder) each connection.
1st Aug 2013 2:54pm |
It's worth investing in the correct crimp tool Warpig if you are going to do your own wiring and check the rating of the fuse you've installed.
There was a thread a while back that went into the various tools available and the pros and cons for each
1st Aug 2013 2:58pm |
WarPig
Good point, ill look onto that, thanks
1st Aug 2013 3:02pm |
