Home > Puma (Tdci) > 52 - 53 mph in 6th
Page 2 of 4 <1234>
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Mines no different clutch in or out. Engine just stops, no vibration, no EGR noise, but then that's due to BAS. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #255088 31st Jul 2013 10:05pm
Caterham
r u sure?
surely the bas map might have an effect on the egr when shutting down but not the clutch......
Shocked (another sleepless night)
so does that along with the kangarooing spel - shot clutch?
(damn - just thought. I hope k9f isn't watching this Cool )
Post #255091 31st Jul 2013 10:07pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Prop UJ?
Reading the above i'd put my money on tyres out of balance. BM52
Post #255104 31st Jul 2013 10:50pm
Caterham
well that does it.....I'll have to get the wheels checked.
can't see it myself but I'll be very happy to find I'm wrong Thumbs Up
thanks.
Post #255108 31st Jul 2013 11:04pm
bm52
i recently had a very similar situation on one of my LR's. They were balanced when new but developed the slight vibration just over 50, now balanced and all is very smooth again Thumbs Up BM52
Post #255112 31st Jul 2013 11:07pm
Caterham
its just I can't see that applying about of acceleration / load onto the transmission how this would affect the wheels to then generate the vibration (speed yes load I can't see)
you're right then thats a great result.
many thanks. will report back once sorted
Thumbs Up
Post #255126 31st Jul 2013 11:33pm
K9F
Re: 52 - 53 mph in 6th
One is apparently supposed to be thankful for small mercies. I just wish this small mercy had been a little longer. Only three days since.......
Caterham wrote:
you won't be hearing much from me now. Thumbs Up
Now you're getting yourself in a tiz over other people's trucks. FFS if you see Caterham walking please don't give him a lift.
Caterham wrote:
Mal - clearly I'm not referring to mine cos mine is now perfect Whistle
Big Cry Big Cry Big Cry Laughing Big Cry Big Cry Big Cry If you go through life with your head in the sand....all people will see is an ar5e!!
Post #255141 1st Aug 2013 3:06am
theorangebandit
52MPH in 6th gear will be labouring the engine, youll get vibration from that. also if you supsect its somethint mor sinister then get underneath and heck your bushes
Post #255150 1st Aug 2013 7:03am
Caterham
yep was underneath last night and so far as I could see it seemed ok except there seemed to be a very small amount of vertical movement in the rear prop and a kind of creaking noise from the drum brake?
only very minor so it might well be normal but I wouldn't have expected anything?
re labouring the engine I dnn't believe its that as on a flat it'll pull cleanly at less then 45.
exhaust made a similar creaking noise (again no more than I would expect) and the heat shiled bolts at the bottom ok. - gonna go have a look at the other bolts in a minute.
(damn - I thought Mal was looking the other way and I'd gone un-noticed Embarassed ) Wink
Post #255152 1st Aug 2013 7:15am
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
Out of shape ...
"labouring the engine"
if I remember, land rover tell us that the engine is fine between 1250 t/min to 2000 t/min ...
but what is good for consummation is mayby not so good for the engine ...
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #255159 1st Aug 2013 7:41am
theorangebandit
It seems you'll be chasing this vibrations for a while I'. Start with a good in depth service of the drive train but I have read back and seven a suggestion to check the balance of wheels which is. Good start
Post #255170 1st Aug 2013 8:27am
Caterham
I can get the wheels sorted but the very slight increase in throttle causes the problem which leads me to think its the drivetrain. also having now noticed just what great difference depressing the clutch makes on turning the engine of I'm thinking thats where the problem lies. ?
Post #255176 1st Aug 2013 8:51am
Happyoldgit
The simple thing to try is drop it down a cog while driving at the same speed [ie change down from 6th to 5th while maintaining the same road speed] and see what happens then. Try the same in other gears at similar rev range, try coasting at that speed too, try running the engine at those revs whilst stationary and in neutral. There you go, lots of things to try and then postulate over.
TBH I think that you rather enjoy having something, anything, to worry and then concoct theories about. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #255185 1st Aug 2013 9:35am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I showed this to my wife last night and her reactions was Rolling with laughter Rolling with laughter Rolling with laughter "They have done what I did when we first got the Defender, they are driving to slow in top gear".
I will say no more. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #255187 1st Aug 2013 9:44am
I always have the clutch out (ie pedal pressed) when starting and when stopping.
What noises do you get when switching off the engine with the clutch in? Rattling from the clutch area as the engine stops is a classic symptom of imminent driven plate failure (the loose spring problem that the Puma became famous for). It could also conceivably cause speed related vibration. Rattling from the gearbox may be backlash (which I think you said you don't have) or imminent adaptor shaft failure.
Have you checked for evidence of a lost propshaft balance weight?
You say that you have "very slight vertical movement" in the rear propshaft. You shouldn't really have any such movement, can you see what is moving? It could from your loose description be diff pinion bearings (ie rear flange moves up and down), rear propshaft UJ (rear end of shaft moves but flange doesn't), propshaft splines (shaft effectively bends in the middle, neither flange moves), front UJ (front end of shaft moves but flange doesn't) or transfer box output shaft bearings (front flange and handbrake drum move up and down). None is good, any could cause vibration and noises.
I do worry that your Defender may end up driving you to the funny farm, and perhaps you aren't cut out for Defender ownership! There are only two things that can happen really with Defender noises/vibrations/defects. They get better, in which case no problem, or they get worse. If they get worse, they get easier to find and fix. Either way there's no point worrying. Thumbs Up
Post #255188 1st Aug 2013 9:48am
Page 2 of 4 <1234>
