![]() | Home > Puma (Tdci) > Britpart Electric Window Kit |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Smudger,
According to the diagram you only need a single relay marked up as R143. The coil protected by a 5 amp fuse link 15 and the contact a 60 amp fuse link 3. Don't know if you have the slot for the relay or fuses in your model but either way it shouldn't cost much. Hope this helps. Treat every day as if it is your last....one day you will be right!! |
| Smudger Member Since: 26 Nov 2012 Location: Basingstoke Posts: 36
Thanks for the advice.
Smudger 08 110 Puma Station Wagon 65 Jaguar XF Sportbrake S 99 Elise 111S Honda XR250 42 Royal Enfield Flying Flea 43 Matchless G3L |
