![]() | Home > Technical > Electrical assistance required please |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
What sort of issue are we talking? A little more specific will help.
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| Macpaul Member Since: 26 Mar 2013 Location: SW Surrey Posts: 439
Edit: comment no longer relevant
Oh and welcome, of course!
| Landyrich Member Since: 04 Sep 2012 Location: Hampshire Posts: 14
Good afternoon, I thought I posted it in the wanted section
However it's the n/ side stop tail,light, works fine with side lights and no ignition, ignition on, the brake light works fine with no ignition, but with ignition on the side light and brake light go out together on that side, all other lights seem ok ?? And thanks for the welcomes |
So it's only the rear N/S brake light only? ____\We|Will|Win/___
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Sounds like a bad earth.Check ALL earths anyways they are the usual suspects. |
| Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335
Check earths, as mentioned, then I'd go over the wires with a multi-meter and check that there's power where there should be.
where abouts just outside basingstoke? |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18034
Without doubt it is an open circuit earth on the affected side. Either filament on its own will light up since it is earthed via the other, but but at the same time = no light (since no potential difference across the series-connected filaments).
Look for a fault somewhere between the light unit and the connection to the chassis. On the Puma the final earth connection to the chassis is somewhere in the vicinity of the gearbox. Since both the filaments you mention are in the same bulb, it could in this case also be caused by a poor connection between the metal base of the bulb and the socket. |
Hi Diablo, I'm in Oakley, if ya passing
Thanks for all the tips chaps, ill get on it and see what I can find, I'm sure understanding electrics is a frame of mind - but not my frame of mind though Got all the fluids n filters done tonight, a small patch welded over a punctured part of the chassis lubed up all the nipples So discs n pads n callipers to go Oh yes and the small matter of a major steering issue the mot missed Just another . Thing on the list aye |
Other side of bstoke to me but still. Might have a free bit of time pop up, depending on when you're free
I woudl go over it well with a multi-meter though, that should reveal all! |
Saturday afternoon, Sunday, and evenings next week , ill finish the nuts n bolt stuff first then have a looky again, kettle n biscuits are always in plenty full supply matey
PM me you address and phone number, and if I get a moment, I can give you a quick call.
The boss has instructed that I'm on tiling duty this weekend though |
