![]() | Home > In Car Electronics > Puma X' over mounting |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
sticky pad tucked up into the dash sorted , in likely to need the removed but velcro pads are certainly going to do the job just the same
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20906 ![]() ![]() |
Good to hear. Just thought I would ask as inside info is the easiest and quickest.
![]() ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
shaun.mobile Member Since: 12 Dec 2011 Location: England Posts: 156 ![]() ![]() ![]() |
Anyone thought of using the seat boxes as sub enclosures?
This is sort of related... I use 3M vercro pads for most things these days. Just fitted the noise-reduction module inside the dash using them. Stuck like glue
![]() Results after it's wired in tomorrow ![]() But shout it at them in German because life is also terrifying and confusing... |
Ze - that was the sort of stuff I was thinking of using myself.
![]() Shaun - ![]() Personally I can't see it being any good the seat box would have to be air tight which is easier said than done. The front on the seat box is relatively small, an 8" may fit but the internal volume would be much to large. Vulnerable to damage by boots etc as well. The lid is too thin again air tight issues and seat clearance also an issue. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
Would probably shake all the relays from their sockets! ![]() .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
![]() Does it really take a Sub for that to happen anyway. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
my 8" jl sub is located in the top of my cubby box, and the amp inside. the lid is screwed down and the insides filled with accoustic quilt. i have put a 8" sub in the rear face of the cubby box but i was never as happy with the sound.
the speaker has got a metal grille on the top to protect it from elbows and my 3 year old son walks over it without problems. ![]() |
Black Tac is the answer better than velcro
FG - If your Amp is sealed in how's it going too keep cool?
![]() ![]() ![]() ![]() Ken - I shall look into that I've got some velcro at the moment so I'll try that but if it doesn't work out I'll try and get some of that. Haven't had the chance to fit my new tweeters yet I'm too busy and more importantly the weather is very un-predictable. Unlike some of you my 90 has to stay outside. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
