Home > Td5 > TD5 Rev counter help
rustandoil
I have eventually got round to fitting the VDO rev counter i bought a couple of years ago to my 2005 110, i seem to have mislaid the original instructions.
I have found several installation write ups on various websites and they all suggest that the trigger for the gauge is pin No.19 on the black connector on the ECU.
On my vehicle this pin location is taken by a yellow wire with a pink tracer.
The Haynes wiring diagram shows a yellow / white wire in pin location No.19
So, i am a bit stuck at the moment, anyone ant idea which pin to pulse the rev counter
Thanks
Post #253061 22nd Jul 2013 7:18pm
bob neville
Same pin, 19. The wire connected already is probably for ABS/TC (not 100% which one or both).
If you don't have ABS or TC you are in luck and the wire will terminate in the dash somewhere and is the feed for a rev counter - some TD5's were pre wired, my 2001 was not.
Best way forward if you have ABS/TC is to splice into the wire at a convenient point.
2013 Defender 90 CSW - sold
Post #253062 22nd Jul 2013 7:26pm
rustandoil
Thanks for the speedy reply Bow down i do have ABS and i am not sure where the wire goes once it enters the loom, i will splice into it at the ECU plug.
Hopefully i will be able to have a go at fitting tomorrow, i will post back with the result.
Post #253306 23rd Jul 2013 5:52pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Just wondered how the rev counter is doing?
I'm thinking about fitting one, I've heard they don't 'keep up' under acceleration too well, please let me know how it goes and what you think of it. Cheers
Post #254522 30th Jul 2013 7:23am
rustandoil
Rev counter is now up and running, if i ever work out how to post a picture i will...
Lambley: yes, i would have to say the rev counter is a bit "laggy" but seems accurate when checked with Nanocom, in normal use this lag is not a problem.
Post #254840 31st Jul 2013 6:46am
rustandoil
A picture just to finish off the thread Very Happy
Post #260497 22nd Aug 2013 9:33am
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Looks good. Thumbs Up
Did you relocate the clock somewhere or just bin it?
Post #260519 22nd Aug 2013 11:26am
rustandoil
I have re-located the clock to my shed and is connected to a 12V battery Smile
I have the facility to display time on my head unit Cool
Post #260523 22nd Aug 2013 11:35am
Arbman Al
Hi
I've just picked up one of these. What other wiring is involved other than the one from the ecu?
Cheers....Al 1996 Defender 130 converted to TD5 and auto
1975 Triumph Stag 3.0 V8
Post #280967 10th Nov 2013 2:22pm
rustandoil
Have a look hrere, its what i used.....
http://www.web-rover.co.uk/nav.php?p=articles/vdotacho
Post #280982 10th Nov 2013 5:18pm
Arbman Al
Thanks for the link Eddie, but doesn't say which wire connects from and to where. I need an idiots guide when it comes to electirics!! Embarassed 1996 Defender 130 converted to TD5 and auto
Post #281232 11th Nov 2013 2:43pm
Martin
Site Admin
It does say for the ECU end - Black Plug pin 19.
The rev counter is marked (from memory) -, + and 2 in addition to the 2 terminals for the bulb. - is ground, + is 12V ignition and 2 is the signal feed from the ECU pin as above.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #281234 11th Nov 2013 2:53pm
Arbman Al
Thanks Martin Thumbs Up 1996 Defender 130 converted to TD5 and auto
Post #281328 11th Nov 2013 8:32pm
Martin
Site Admin
No problem Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #281531 12th Nov 2013 11:14am
ppad
United Kingdom 2005 Defender 90 Td5 HT Caledonian Blue
Picking up this thread, while I'm between jobs might as well play with the truck.
Just want to double check first...
OK it's a dumb q but it's never actually mentioned from which direction you count ..
1) Pin 19 is looking from the underside so to speak? (the socket side)
2) Therefore my pin 19 is unused - between a pink and a red/green?
I'd like to double check because this is not the Haynes manual colours
3) And mine being originally designated a 'commercial' vehicle ie van therefore never intended to have central locking, ABS, etc etc --- will pin 19 be 'live' anyway or should I check? I have no access to oscilloscope.
Thanks Sold the much modified 110 2.8, in Oz
Brought the 90 home from Switzerland ...
Post #558874 25th Aug 2016 3:33pm
