![]() | Home > Puma (Tdci) > Heater Stuck on Hot, any ideas? |
| Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982
Even if I turn the heater down, it is on full. Before I hunt around with my trusty hammer, I would appreciate any advice from you if you have had the same problem.
Thanks, Merlin |
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
I wish
Steve |
| sc70 Member Since: 29 Jun 2010 Location: Tregaron Posts: 261
had that on mine, it was the end of the cable where it goes into the heater under the bonnet, there is a white valve type thing on top of the heater and the end of the cable has an eye on it which had bent. Just un clip the cable and straighten with a pair of pliers, the cable has too push the valve to get cold air and mine was only bent a little bit but was hot all the time.
Hope my c*ap description helps Main Dealers for Equi-Trek and Brian James Trailers |
| skyeplumb Member Since: 22 Apr 2013 Location: Isle of Skye Posts: 134
Mines not fully hot when on cold, but warm, then 1 click towards the red it's full on ( might as well be a switch not a dial)
I've not looked ate the cable yet - just switched the AC on! Discovery 1 300Tdi - Sold Defender 110 XS 07MY Utility |
thats how mine was, also when you turned the dial it wouldnt go fully round to hot www.Equi-Trek-Tregaron.co.uk Main Dealers for Equi-Trek and Brian James Trailers |
| pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489
See above, had the same thing and moving the cable sleeve back to the correct position and closing the clip properly solved my problem.
Double post
The heater control valve seems stuck. Any idea what the part number is?
Merlin |
| ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831
Just a thought. Have you got the selector set to recycle or to draw in fresh air? Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to Richard |
Fresh air, just ried it and there is no difference.
Merlin |
We had the same problem 2 weeks ago, the 110 was that hot inside we had to stop and get out, the wife soon sorted it after finding that the selector was on recycle (across to passenger side), after moving it and running for 5 minutes it started to drag in cooler air. Don't make old people mad.
| All times are GMT |
