![]() | Home > Technical > Defender Puma Clutch Issues |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2497 ![]() ![]() ![]() |
I guess you do not have a code reader? Puma 110" SW
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
I have but at this point in time my patience with the dealer and the vehicle is running out. I will not be accepting the vehicle back until all of the issues are resolved or there is a plan in place to get things resolved.
I have purpose built this vehicle to carry out a specific job. To date its not earning is keep as its been in the dealers more than I have had it on site. I would be better off sticking a TDV8 with auto box and beefing up the drive train. Rant over 130's have feeling's as well you know ![]() |
Been there. Very frustrating to deal with "dealers" as they are not very capable. Puma 110" SW
JMS Member Since: 05 Mar 2010 Location: Isle of Wight Posts: 40 ![]() ![]() ![]() |
Very interesting. i started experiencing item 3 after a LR ECU update last year and it was getting worse so booked in to get looked at. Got the car back on Friday after yet another ECU update, injector re-program (as they were out) and some Pilot correction thing??? Now i have item 2,4,5. I have not driven far enough or long enough to get item 3 but to be fair that might have been fixed... ![]() BACK ON TOPIC The clutch however has done 22k miles and is ok! (now i have said that it will be broken tomorrow ![]() |
Pretty disappointing Andrew considering how much time and effort yourselves put into your vehicles let alone money. It seems that since we went electrical then there is no two engines the same. My DCPU is very smooth and quiet and drives witrh no problems engine wise. It still has the usual drive train clunk and I'm pretty sure it'll need a clutch before too long. My 90 (tune on it) has a noisier engine but a nice tight drive train. I hope that they get Jlo sorted to how she should be. How is Lara in comparison. Original Member Pie n Pea Club.
110 HCPU Tipper |
Anybody contacted LR customer service? I did it by fax (I`m overseas) and got no asnwer at all
![]() ............................................................. Earth first. Other planets later |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2789 ![]() ![]() |
veeeeery old topic i know, and new poster (hi)
I have a '10 2.4 110 and its just about to have its 3rd (i.e.. second change) clutch. Just wondering if anything further was established about the cause of tdci's chewing clutches and if theres a way to fix it? Also - did people find that the clutch could be changed under warranty or not? doesnt look like mine will be! ![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
My clutches were changed under warranty and there was a modified part that certainly for the remaining time i had my defender for, seemed to cure it Mike
do you have any more information please? i would VERY much like to be able to trust my clutch in the future! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
AFAIK new friction plates have a glossy golden look on the metal. Make sure you are not getting the outdated stuff. Puma 110" SW
You should get it replaced under warranty, if not then ask for a good will gesture from LR, call customer care be polite and they may pay a large % As far as the replacement parts are concerned they should fit the latest modified version, clearly a false economy to fit out dated older parts ![]() |
landybehr Member Since: 17 Apr 2013 Location: -D- Posts: 173 ![]() |
follow the links - there´s a pdf to look at:
http://www.blacklandy.eu/blboard/forum/sho...post938468 sorry > EDIT = pdf can only be opened if registered. No help then for you. There are pics of the different clutches. It´s a service bulletin, IIRC. |
Andy80 Member Since: 31 May 2013 Location: Essex Posts: 492 ![]() ![]() ![]() |
I've just been reading this thread and thought I would comment, Mk is correct with his summary saying about the development as back in mid 2004 ,I was asked by the company I worked for to visit Rousch Developments. They were building two mule td5 defenders to take tdci engine for Solihull, At the time the development engineer was unhappy with the characteristics of the engine to be suitable in a defender with torque and vibrtation issues from the outset....... Working towards Carry on camping! |
I´m not sure I fully understand. The fault lies in the friction plate, doesn´t it. Is this part specifically designed for the Defender ? Even if so (how does it influence vibration issues? (*)). The space provided is defined by the flywheel and bellhousing/gearbox. What I want to say is - if there is a setup which runs (don´t know much about the Transits. But their main utilisation might imply that the clutch cannot be accepted to be a weak point) without problems in the "donor vehicle" i.e. Ford Transit - then why does it start to spell trouble in the Defender. Furthermore to my knowledge it´s the early 2.4 Defender only to suffer. Later 2.4 and all 2.2 don´t (but I wouldn´t put my hand on the bible for that). It is completely hypothetical but I´d say that LR tried to make the clutch easier to operate and used a different clutch setup. Later they turned to a H/D setup, being standard on the parcel-service-Transits. No more faults, but less comfortable to use. Although it cannot be only the friction plate that was being changed. I need to repeat - fully hypothetical. Please do not spread the word unless someone with firm knowledge says sth. similar. Or, just as good, tell me it´s rubbish. (*) and after all - transferring engines to other vehicles is not totally uncommon. I, personally, think that a commercial vehicle like the Transit wasn´t the most unsuitable donor. Nissan had taken a much worse choice with the 2.8 6cylinder passenger car Diesel some 20 years ago. |
