![]() | Home > In Car Electronics > Interference reduction? |
Hi guys
Earlier this year I fitted several USB sockets powered off the lighter circuit. Two are for a TomTom iPhone cradle and an iPad. They work great but when I play music into aux from the cradle, I get rpm-dependent noise at higher volumes. Do you reckon fitting one of these: http://www.ebay.co.uk/itm/10A-NOISE-SUPPRE...4cefcf5a31 in the lighter circuit will work? I used one (just preventatively) for the powered sub "from new" so I have no idea if they really work. Cheers for any advice Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
At the price it's worth a punt anyway. We use similar on the boats and they do work.
![]() Treat every day as if it is your last....one day you will be right!! |
Cheers Mal - I'll give it a go
![]() But shout it at them in German because life is also terrifying and confusing... |
Matt,
Just remembered. Not so good I found if you're running a subwoofer or auxilliary/pre amp as they are that good it will suppress these too which defeats the object. ![]() Treat every day as if it is your last....one day you will be right!! |
Well, the radio/aux is run off its normal loom. Its speaker outputs are tapped to the sub, which takes its power (fused) from the battery with one of these gizmos in between. I guess the radio loom is already noise-reduced somehow.
The power supply for the cradles/phone/music is tapped from the lighter circuit, which I suppose would not normally need to be interference-free, i.e. it's very noisy! One thing I'm not sure about is where to earth the gizmo. Ideally it should screw to the bodywork but I wonder I I could tap onto another earth cable in there ![]() I admit ignorance about these electronic things, as normally whenever I try to change something, the rest gets worse. However, as you say, its only a few quid and worth a shot, especially if it works in some situations. Only real cost is the time to get the dash apart again ![]() Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 597 ![]() ![]() ![]() |
Do your speaker cables run past any of the main power cables for the car, the one that runs to the battery/from alternator? Seeing as there's no ignition system I'd guess it's alternator noise.
It's a weird setup, I guess - the aux doesn't normally have any problems with iPhones/mp3 players etc. The radio/aux and its cables seem to be okay. It's just when I use an iPhone which is being charged from the cradle/lighter circuit. As you say, I guess its alternator noise being fed (via the lighter wiring) into the aux. I'll try the gizmo and coaxial cable idea and report back ![]() Cheers guys Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
I've got a similar problem, but I have wired a triple power and USB socket directly to the battery via a 20amp fuse and ignition switched relay. Definite engine/alternator speed related interference when using my iPod plugged into the USB socket and into the auxillary input on the Head Unit. So I'm interested as to how you get on!
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17853 ![]() ![]() ![]() |
When I used to run a USB device powered from the lighter socket it suffered very badly from (what sounded like generator-induced) interference. Running a feed directly from the battery sorted the problem.
As mentioned previously using a 'screened' cable (something like SY perhaps if routing underneath the truck) and grounding out the screen should also prevent interference.
What Mal said above is well worth taking on board. The same goes for RCA cable too and if ever you have audio cables and power cables that have to meet ideally they should cross over at a right angle so that there is as little close contact as possible.
I know it involves perhaps a different HU or maybe even not possible to use your device in the way you want to but this is why I use a manufacturer made and "made for iPod" HU & cable which powers the device controls it and plays the music in one plug all running of the HU. By charging via an external USB and playing via the 3.5mm audio jack you are creating an electrical loop inducing interference noise / electrical noise. (happy to be corrected on this though) Also make sure the audio jacks are fully inserted as that can cause some noise and also perhaps try a different cable for the sake of it. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Where do you wire into,on ours when you select reverse aload of interference comes through the speakers 2.4 90 XS
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1447 ![]() ![]() ![]() |
Earths are the first place to start. the shorter the better and more effective. I would also check your getting 12+ volts out of your sockets, especially when they are all in use. Someone else has already said they wired them separate which seems like a good idea as well as maybe solving the problem.
I get exactly the same with the standard radio setup and I am 100% sure it comes from the (cheap) LED reversing lamp I installed. *UPDATE* 1) First it didn't work... 2) Then it did ![]() 1) The cradles are powered from the lighter terminals so I put the noise-filter between the (+) lighter terminal and the (+) cradle, earthing it to the body via this fuse holder stud: [URL=] ![]() Click image to enlarge[/URL] However, it only cut out 50% of the noise ![]() 2) Then I realised I was still using the (-) lighter terminal as earth for the cradle - probably still a source of noise ![]() So I took the cradle (-) to the same fuse holder stud and Bingo! Hardly any noise now - my classical collection can again be heard ![]() Finally, proof of my trust in 3M Velcro: [URL=] ![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() But shout it at them in German because life is also terrifying and confusing... |
