Home > Wheels & Tyres > Locking wheel nut - Stuck!
Page 1 of 3 123>
excossack
Tried to remove the locking wheel nut to remove the wheel and the locking wheel nut slipped off the nut. Looking at the removal socket and its split.
So any ideas on how to remove the locking wheel nut ? and how do I ID the correct model/type/code for a replacement socket? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #252659 20th Jul 2013 9:23pm
GUM97
Not sure if this is any good for Defender nuts?
http://www.screwfix.com/p/laser-emergency-..._container
Or...
http://www.machinemart.co.uk/shop/product/...emover-2pc
This one looks quite nifty...
http://www.lockingwheelnutremover.co.uk/
Regards
Pete An engine to TDi for!
Post #252668 20th Jul 2013 9:34pm
excossack
Interesting but
"4 x 38mm ½" drive locking wheel nut removers (17, 18.5, 21.5 and 26mm) and a metal storage case."
26mm ? Landy ones are 27mm. 1999 Defender TD5 110
Regards
John M0VAZ
Post #252670 20th Jul 2013 9:37pm
GUM97
Ah, maybe that's not such a good solution then! Embarassed An engine to TDi for!
Post #252672 20th Jul 2013 9:41pm
GUM97
Oh, on another note, I've got a set of 4 locking nuts that you can have if you want them Thumbs Up An engine to TDi for!
Post #252674 20th Jul 2013 9:42pm
NickEJ
Slovenia 2004 Defender 90 Td5 XS CSW Galway Green
If I understand your problem correctly, the wheel nut with have a letter stamped on it. Just tell the dealer the letter and they'll sell you the right socket. I think, from memory, that there are about 12 variations.
Post #252676 20th Jul 2013 9:47pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
If you have the standard fitment locking wheel nuts there should be a code stamped on the removel tool,your local main dealer will be able to supply a replacement. 2005 Td5 90 XS
Steve
Post #252677 20th Jul 2013 9:49pm
excossack
Cheers, I will have a look for a marking on the removal tool. 1999 Defender TD5 110
Regards
John M0VAZ
Post #252692 20th Jul 2013 10:25pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
As Lou says Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #252699 20th Jul 2013 10:43pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Yup as above, there should be a letter stamped.
Apparently dealers sell loads of them as they won't withstand the windy guns/impact wrenches that Kwik Fit etc use and they shatter all the time.
Post #252724 21st Jul 2013 8:05am
excossack
I think that's what's happened but not sure when! 1999 Defender TD5 110
Regards
John M0VAZ
Post #252729 21st Jul 2013 8:52am
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Mine went on my RRS recently. Had to have them drilled out, £160 later all removed Twisted Evil
Lockers had corroded over time so that the security socket was ineffective.
Now don't have locking wheel nuts - much easier. 2007 TD5 90 Hard Top
Post #252782 21st Jul 2013 3:34pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
Same with the wife's D3, my adaptor went missing, I went to see the mechanic's at Stratstone Cheltenham and they gave me one of their spares for free, he said loads of them get "left" behind after work being done (which I suspected happened to mine, until wifie found it in a box she used to remove stuff from car proir to service Rolling Eyes ) Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #252790 21st Jul 2013 4:23pm
GUM97
^^Well, some people will decide to drive Range Rovers Whistle Rolling with laughter An engine to TDi for!
Post #252791 21st Jul 2013 4:23pm
Retroanaconda
Just hammer a very slightly smaller socket on. Worked for me when I bought a 110 with locking nuts but no key, got all five off no problem and threw the stupid things away.
Post #252794 21st Jul 2013 4:38pm
Page 1 of 3 123>
