![]() | Home > Puma (Tdci) > High Revs for ~ 2 secs+ when changing gear foot off throttle |
| max peck Member Since: 30 Aug 2012 Location: Dubai Posts: 17
Hello Guys,
Just a quick question for you guys. What are the effects on clutch wear with this feature (i.e holding revs between shifting)? Does it result in increased wear do you think? Regards, Max |
| borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677
I tried this and it was terrible to drive, clutch judder from hell! |
| tact Member Since: 03 May 2013 Location: Kuala Lumpur Posts: 16
Hey mice72sg! I am in KL with a 110 DC MY2013. Almost neighbours. Plenty of offroad opportunity if you cross the causeway. Was that ferrari frown along Orchard Rd? hehe Proud new owner of a 2013 DCPU (SALLDHSR7DJxxxxxx) - "Manny" (from "Ice Age") |
| william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259
I did this and jeez its a sports car now Easier to drive and also feels quicker as you can change gears faster rather than having to wait for the rev to drop (this was a 2.4 btw) William |
Anyone who has done the mod - how does this impact the idle jack feature?
When you are in low range first, this feature is supposed to detect clutch pedal out then boost idle revs to around 1000rpm. (This is apparently done because normal,idle revs in low first are too low for safe descents on steep hills) Presumably this doesn't work with pedal switch shorted? Proud new owner of a 2013 DCPU (SALLDHSR7DJxxxxxx) - "Manny" (from "Ice Age") |
must be different on the 2.2 then, or at least mine, as it really was undriveable when I did this. |
