![]() | Home > Maintenance & Modifications > Replacement windscreen hinges |
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 ![]() ![]() ![]() |
is that the big bulky bits that stick out at the bottom either side of the windscreen that used to be hinges and now look static and just for show?
if so mine are corroded and getting replaced under warranty on 8th August. How can yours not be under the LR warranty and mine is? =================================== Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
The two 'Dummy' Hinges should be covered. Mine were. It may be a case that the dealer is telling you that to get you to pay, but they have put the warranty claim into Landrover so they get paid by them as well. Even though this is fraud it happens quite a lot. There should be a register at Landrover(maybe Mike can help you with this) of what Warranty work has been applied for and approved. |
miket Member Since: 05 Oct 2012 Location: Peak District Posts: 143 ![]() |
Thanks both - I've followed-up with Mike.
Dealer BS
![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Bought mine genuine from Lrseries.co.uk. Had them painted and 3 yrs later they are corroding again. They seem prone to corrosion.
For the absolute ultimate Windscreen Hinges try www.ox4x4.com. They make some lovely polished Stainless Steel Door Hinges, Etc...., but I have to warn you....they are not cheap
Be VERY careful about replacement door hinges....... ![]() Re OX4X4 ones....Unless they've reworked them.....
Never mind about faded paintwork on a Puma they're sprayed hinges on! Take the hinges off and all you've left is primer. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 16th Jul 2013 7:14pm. Edited 2 times in total |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Pretty sure I have seen an Ali replacement as well (also black anodised) Croytec maybe? I think k9f has a set.
Hope mine don't get corroded , there area couple of stone chips which seem ok at the moment ![]() DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
Bang on the nail DJ....
![]() I've Croytec hinge blocks, Stig Fastener stainless door hinges and OX4X4 bonnet hinges..... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Site sponsor MPS sell some nice looking ali hinge blocks. They even offered a deal on them recently. Darren
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
I got some black ones from paddock very cheap and they look good and have lasted well so far.
Pete. |
stock ones are about £15 each, SHG @ MPS trading has anodized ones for sale on his site
(Note: they are sided L & R hand) |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6214 ![]() ![]() ![]() |
I've got one side here, I'm looking for another (can't remember which i've got) but i plan to get them powder coated.
should last well then?? |
I got a couple PC'd cost £5 and look ace, might not be as durable as anodized. Frost sell anodizing kits |
