![]() | Home > Maintenance & Modifications > Fitting instructions soft front A bar |
| 238kirk Member Since: 03 Nov 2012 Location: Doncaster Posts: 233
It's not too difficult, if you have all the brackets then its pretty self explanatory, if its the newer type which I think it is then you fix the bottom brackets to the a bar, they then bolt under the bolts that hold the bumper on and the towing points, fix the top brackets to the a bar and they sit over the top of the grill surround and under the bonnet, you will need to drill these to the grill surround, done
I've seen some instructions that I think lro did a while back, I'll see if I can find it |
Here's the link, it's for the older type but pretty much the same, the bottom brackets bolts through the a bar but yours will bolt to the back and you obviously haven't got the light guards either
http://www.makitauk.com/pam/custom/files/LRM-PaddedBar.pdf |
| madrunner Member Since: 24 Jul 2012 Location: Dorset Posts: 68
You absolute legend sir ! Thank you
This is a perfect example of how bloody good this forum is. If I meet you sir, there's a beer with your name on it. |
| Bill2812 Member Since: 29 Apr 2013 Location: Colchester Posts: 19
Hi I have just fitted an A bar to my 110
It really is not too bad about 30 mins and all done You only have to loosen bolts on the bumper as fixings slide into place and only 4 holes to drill on top brackets. I looked up some old threads found one by mao9999 who had scanned in the original fitting instructions from his A bar. It really is a simple job just take your time . |
Awesome - yet another top nugget of a reply !
Cheers |
| All times are GMT |
